if you are talking about an identifier for automation, then you can see it in the url when you go to the device page in hass.
Changes in v2.9.0
NEW DEVICE
- Add support Xiaomi Home WiFi (RB08)
BREAKING CHANGES
- Added VPN connection status and uptime
After update Home Assistant to 2023.2.5 i have error:
Detected integration that called async_setup_platforms instead of awaiting async_forward_entry_setups; this will fail in version 2023.3. Please report issue to the custom integration author for miwifi using this method at custom_components/miwifi/init.py, line 100: hass.config_entries.async_setup_platforms(entry, PLATFORMS)
Please update integration.
Thanks.
Changes in v3.0.0
BREAKING CHANGES
The minimum version of HASS has been raised to 2023.3.0 - #115
- Removed deprecated DEVICE_CLASS_* - #110
BUGFIXES
- Fixed a bug in the service - #109
- Fixed tests
- Fixed pylint
NEW DEVICE
- Add support Mi Router 4A Gigabit V2 (R4AV2) - #114
- Add support Xiaomi Router AC1200 (RB02) - #116, #117
- Add support Xiaomi 5G CPE Pro (CB0401) - #118
Hello!
Could someone help me, because after the last update, I wanted to add the integration, but it does not accept the IP of my device (AX3000).
Hey there,
I was wondering if anyone could assist me with converting the unit of the WAN speed from B/s to MB/s. I’m having a hard time trying to figure this one out.
Any help would be appreciated.
Thanks.
type: custom:stack-in-card
cards:
- type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: custom:mushroom-entity-card
entity: sensor.miwifi_a4_39_b3_69_2c_2c_wan_download_speed
layout: vertical
card_mod:
style: &style |
ha-card
{background: transparent;
border-style: none;
--primary-text-color: white;
--icon-size: 25px;
--icon-symbol-size: 1em;
--icon-border-radius: 10px;
width: 110px;
mushroom-card {
padding: 5px 1px 5px 1px;
mushroom-shape-icon {
--shape-color: none !important;
--shape-color-disabled: none !important;
entity: sensor.miwifi_a4_39_b3_69_2c_2c_wan_upload_speed
primary_info: name
layout: vertical
card_mod:
style: *style
entity: binary_sensor.miwifi_a4_39_b3_69_2c_2c_wan_state
layout: vertical
card_mod:
style: *style
entity: binary_sensor.miwifi_a4_39_b3_69_2c_2c_state
layout: vertical
card_mod:
style: *style
- type: custom:mushroom-chips-card
chips:
- type: entity
entity: update.miwifi_a4_39_b3_69_2c_2c_firmware_update
- type: entity
entity: sensor.miwifi_a4_39_b3_69_2c_2c_devices
- type: entity
entity: button.miwifi_a4_39_b3_69_2c_2c_reboot
content_info: name
alignment: center
card_mod:
style: &style2 |
ha-card {
background: #1c1c1c;
padding-left: 15px;
padding-right: 25px;
padding-bottom: 25px;
same problem… did you solve it? How?
Hello, after updating to 2024.1 the following started appearing in my log files:
Logger: homeassistant.components.device_tracker
Source: helpers/deprecation.py:205
Integration: Проследяване на устройства (documentation, issues)
First occurred: 18:16:53 ч. (2 occurrences)
Last logged: 18:16:53 ч.
SOURCE_TYPE_ROUTER was used from miwifi, this is a deprecated constant which will be removed in HA Core 2025.1. Use SourceType.ROUTER instead, please create a bug report at Issues · dmamontov/hass-miwifi · GitHub
Logger: homeassistant.const
- DATA_MEGABYTES was used from miwifi, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfInformation.MEGABYTES instead, please create a bug report at Issues · dmamontov/hass-miwifi · GitHub
- TEMP_CELSIUS was used from miwifi, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfTemperature.CELSIUS instead, please create a bug report at Issues · dmamontov/hass-miwifi · GitHub
can you help me to solve the problem.
thanks
Has anyone managed to connect recently?
I have the Xiaomi Router AX3000 (RA80), and like the friend above, it does not accept my IP!
Hello, did someone managed to accept the ax3000 ip?
I have a Xiaomi AX6000 router.
I managed to connect it to HOME ASSISTANT.
I am trying to block a device with the following service:
Or Mozes, [02/07/2024 15:04]
service: miwifi.request
device_id: … # Device ID (It is the router)
uri: xqsystem/set_mac_filter
body:
mac: 00:00:00:00:00:00 # MAC address of the device we are blocking
wan: 0 # 0 - block, 1 - unblock
HI,
i see this working in the log
StrEnum was used from miwifi, this is a deprecated alias which will be removed in HA Core 2025.5. Use enum.StrEnum instead, please report it to the author of the ‘miwifi’ custom integration
- ServiceCallType was used from miwifi, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.ServiceCall instead, please report it to the author of the ‘miwifi’ custom integration
- HomeAssistantType was used from webrtc, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.HomeAssistant instead, please report it to the author of the ‘webrtc’ custom integration
- ServiceCallType was used from webrtc, this is a deprecated alias which will be removed in HA Core 2025.5. Use homeassistant.core.ServiceCall instead, please report it to the author of the ‘webrtc’ custom integration
how I can report it to the maintainer?
kommt ein update damit es auch für denn Xiaomi Router AX3000 NE geht ?
For the ones trying to make it work with AX3000 V2 (RA80V2), I managed to make it work with some workaround.
Same for me
Is anyone experiencing issues with the latest core update 2025.01, and if there is anything we must do or wait for an update?
I assume it relates to the following:
Refer to the following to fix the issue:
Important Update for MiWiFi Integration Users on Home Assistant!
The original MiWiFi integration hasn’t received any updates since 2023. For that reason, I’ve created a new and improved repository with continued support, compatibility updates, and new features.
New repository:
GitHub - JuanManuelRomeroGarcia/hass-miwifi: MiWiFi for Home Assistant
I recommend updating your integration to take advantage of the improvements and active development.
Key changes:
Expanded support for newer models
Bug fixes
Better device tracking and repeater mode handling
Improved sensors and entities
Thanks for supporting community-driven development!
