HA have Xiaomi integration with variuos vaccum model, but no integration with:
NAME: Mi Robot Vacuum-Mop 2 Pro
MODEL: ijai.vacuum.v3
Maybe somebody know how to integrate to HA ?
Did you find a solution? I have same product
I Find a solution
Unfortunately is not compatible with mop 2 pro
It does integrate with the basic Xiaomi integration, but it only has basic functionalities. I would need the function to be able to send it to a specific room, and/or select cleaning mode (I mean vacuuming, mopping or both).
Thank you! This do the trick
Please consider this integration available on HACS: GitHub - Tasshack/dreame-vacuum: Home Assistant integration for Dreame Gen2 Lidar robot vacuums with map support
For Mi Robot Vacuum-Mop 2 Pro, the model is dreame.vacuum.p2150a
The integration is full of features!
Hi! Thanks for your message.
I tried to install the integration you suggest but during the installation it tells me that there are no compatible devices in the cloud (my vacuum is Xiaomi Vaccum-mop 2 pro). What can i do?
Support for VSLAM robots will be added soon. Please follow the related issue about this on the repo.
Same here, only start/stop, return to charging station works. No sign of zone cleaning
Did You fix the issue and successfully add device to homeassistant ? Because during installation also tells me that i have no compatibile devices in the cloud.
Hi all. Bought the vacuum “for my wife” hoping it will be done before I got it. Not yet
Thank you for all the hard work.
Today i got my new 2 Pro Vacuum.
I tried the miio Integration and the dreame Integration, but both doesn’t support the model.
Is there a Chance or Timeline when the vacuum will be supported?
@tasshack said that it will be supported with VSLAM robots, but it’s clearly not supported still
You must be using ijai device but only Dreame devices are supported.
Поддержка Xiaomi vacuum mop 2 pro (ijai.vacuum.v3) - Запросы функций - Сообщество Home Assistant
al-one/hass-xiaomi-miot: Automatic integrate all Xiaomi devices to HomeAssistant via miot-spec, support Wi-Fi, BLE, ZigBee devices. 小米米家智能家居设备接入Hass集成
Используйте это.
Нужно использовать приложение Mi Home от vevs с включённым логированием данных
