question, if the Xiaomi Philips Light is configured using the Xiaomi gateway , can the use the same token from the gateway for the Xiaomi Philips Light ? and what would be the host IP ?
light:
Ta LeeB
do you manage your bulb this way finaly ? I’m interrested too, as I wont do the boring trick to get this stupid token !
no … gave up and move onto Sonnoff bulbs
These are Wifi, they don’t connect to the gateway.
@sjee correct, so I MUST find the token ? there is no other way ?
