I’m struggling setting this thing up. I’ve set it up within the Mi Home app within the Singapore region (closest to me). I’ve extracted the token from within the SQLite DB but I’m getting the following error on HA startup:
2019-03-13 13:16:08 ERROR (MainThread) [homeassistant.components.vacuum] xiaomi_miio: Error on device update!
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 248, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 348, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/xiaomi_miio/vacuum.py", line 397, in update
self.last_clean = self._vacuum.last_clean_details()
File "/usr/local/lib/python3.7/site-packages/miio/vacuum.py", line 194, in last_clean_details
last_clean_id = self.clean_history().ids.pop(0)
IndexError: pop from empty list
Sorry to bring up an old thread but I have just tried to set up my Roborock S5 but I’m having issues.
config:
vacuum:
- platform: xiaomi_miio
host: 192.168.0.152
token: 32xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx # not my real token...
error:
Log Details (ERROR)
Logger: homeassistant.components.vacuum
Source: components/xiaomi_miio/vacuum.py:294
Integration: Vacuum (documentation, issues)
First occurred: 14:46:26 (1 occurrences)
Last logged: 14:46:26
Error while setting up xiaomi_miio platform for vacuum
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 186, in _async_setup_platform await asyncio.gather(*pending) File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 295, in async_add_entities await asyncio.gather(*tasks) File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 446, in _async_add_entity entity.async_write_ha_state() File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 297, in async_write_ha_state self._async_write_ha_state() # type: ignore File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 314, in _async_write_ha_state attr = self.capability_attributes File “/usr/src/homeassistant/homeassistant/components/vacuum/init.py”, line 344, in capability_attributes return {ATTR_FAN_SPEED_LIST: self.fan_speed_list} File “/usr/src/homeassistant/homeassistant/components/xiaomi_miio/vacuum.py”, line 294, in fan_speed_list return list(self._fan_speeds) TypeError: ‘NoneType’ object is not iterable
running HA 0.110.5, any ideas? I tried the solution above regarding letting it do a clean and return to dock then restarted HA… no luck
