Xiaomi Robot Vacuum - Cant start of from dashboard switch
Hi, i Just added my Xiaomi Robot Vacuum v1 in my Raspberry Pi Hassio environment. Everything works just fine if I try to control It from inside options.
But, if I try to use the switch from dashboard nothing happens.
I already used It on my older home Assistant evironment and everything was Just fine. Maybe it does not work with the latest hassio version?
The header toggle doesn’t do anything on my build as well.
Just click on the Xiaomi text line, there you can manage the vacuum.
