Xiaomi sensor in 106.02
HELP! I have Hassio on RB. Tonight I updated to 106.2 and the XIAOMI sensors connected with the respective XIAOMI gateways no longer work. On the latter, through the XIAOMI app, the sensors work but in HASSIO not. Entities are recognized but I don’t see updates. For example: the temperature sensors at the first boot measure the actual temperature but afterwards it no longer updates. Same goes for motion and vibration sensors.
Same here.
Today i updated from 105.5 to 106.2 and the Xiaomi Sensors stopped working (updating).
I downgraded to 105.5 and i am looking forward for a solution.
Thanks to all…
the problem is the supervisor version, specifically 206, not the home assistant version
How did you downgrade? I tried to downgrade to 204 but after installation it was automatically upgrade to 206 again?
Same here - I believe it was the Supervisor update that triggered it.
I only updated to 106.2 and it stopped working.
I did NOT update the supervisor.
With (untouched) supervisor 201 and the downgrade to 105.5 it works like before
Oh okay :slight_smile:
Did you update HACS to v22?
confirmed, hacs is the problem
Oh, yes, i did.
Will check it out later.
Thanks for the update
That is not confirmed, and highly unlikely.
It’s my case and 7 people at least, I honestly think it’s more than likely
V 0.22.1 Disable socket test due to flaw in PyXiaomiGateway
I guess now is confirmed
Updating to HACS 0.22.1 solved the issue for me too
Same here.
HACS 0.22.1 fixed it.
Thanks for the quick response @ludeeus
