Xiaomi Sherlock Smartlock
Do you have to use the UART connection to use an esp board to open and close the lock? You mentioned that when you restart the esp the it causes the lock to lock or unlock, is that related to the ESP-01 board pins or will have the same behaviour regardless of the the board, I am planing on using a Esp32-C3
I found my unused brand-new sherlock s2 with 5 bluetooth key fobs…
and happily logged now in 2024 to the bluelok app to use it… but i see i threw my money away hahahahahahahaha
I hope someone can find a solution almost to use the product with the BT keys or another platform.
Any news?
I should have realised when I bought it years ago (I just found it unused now in 2024 along with 5 bluetooth remotes) that using an email [email protected] (that comes printed in the packaging) was not very corporate and serious hahahahahahaha.
the ios/android bluelok smart app disappeared from playstore/appstore.
what is going on ?:slight_smile:
Needed to buy a new lock because of this. Hopefully someone finds a way to reflash this (other than that) good hardware…
Hi
I have smart lock with bluelok app version bluelok_google_release_v1.0.12_23031600_zipalign.
Now, I cannot logging to my account.
If someone has a solution, please wrote.
i am currently using the remote button with an esp32, if it ever gets reset, need to tap into the lock itself to press the lock/unlock buttons. dont want to do this yet, since the battery will drain a lot faster with a wifi module connected. anybody done this already ?
Does anyone know if it’s a BLT (the button )
And if so, how can it be recorded?
This append to me lately, switched to Nuki now
It seems bluelok enterprise has dissapear…
The remote button is bluetooth, I have It attached to a 8266 with esphome too… The commands are encrypted, can’t intercept those commands…
Another approach maybe…
“Estimated battery life (GWA1501). 2 years” CR2032 battery
2 dry contacts zigbee switch hooked to the physical buttons of the lock?
3d print black enclousre and double side tape under the lock…
I have a extra key that I forgot add.
Is there any possibility to add?
Anybody had tried to reply the app changing the server?
Hello, I want to do the same type of assembly with some differences and I would need advice:
  • I want to use ESPHome. Replaced the touch button (it is broken) with two push buttons.
  • Remove the battery and connect a live power supply. (or keep the battery but leave an external power supply connected continuously)
  • Connect a WIEGANT keyboard.
Do you have any advice for this?
Thanks in advance.
