For anyone out there trying out the new Zigbee HA support, I’d be really interested to know if the Xiaomi Smart Home devices can be made to work without the gateway?
Agree nice to have the ring and light sensor…
But the gw phones home/requires internet and also requires Chinese socket or adaptor.
I would def be interested as to whether it’s possible drop the gateway… even if I decided to keep it
This post is an old one but i juste have the same question, … so in place of create a new one, does anybody have do it ? (using something like the aqara and humidity temperature sensor without using the gateway)
I’m running HASS in Docker on my Linux server and I can confirm that zigbee2mqtt is working there perfectly. I just installed the zigbee2mqtt docker container. All you need for the CC253x dongle is a USB slot.
You do need to program the dongle with some custom firmware, but that’s not too difficult if you have the programing hardware and follow the instructions.
The CC2531 is the usb dongle, you can plug it directly in a RbPi (better use an usb extension cable). The CC2530 does not have usb, so you need either a ftdi adapter to plug it into your RbPi, or an esp8266 to connect to it over Wifi.
and do you know the range of the CC2531, cause actually my aqara gate is in the center of the house, but if use a cc2531 connected to the rpbi, it will be in the garage (in a rac) … not sure it will be good
That is exactly the reason it switched from a CC2531 to a CC2530 with esp01. Since I don’t have any zigbee lights that can act as a router. The CC2531 was connected on my RbPi in the back of the house, now I have a CC2530 in the center of the house.
i’ve see some CC2531 with antenna, … maybe range is better.
your esp01 is a wifi stuff ? (I didn’t know anything about electronical component)
Do you know if it is possible to use a “component” used for connecting an cc2530 (or 2531) to an rj45 ?
if your cc253x is not connected directly to you rbpi, is there something special to do for using it with hassio ?
Just to add, conbee II with deconz is working pretty well with xiaomi sensors and philips hue. I managed to get rid of the xiaomi gateway and philips hue gateway with this setup under hassio.
