SETUP:
- Home Assistant 2023.1.7
- Supervisor 2022.12.1
- Operating System 9.4
- Frontend 20230110.0 - latest
- Xiaomi Smart WiFi Socket model chuangmi.plug.hmi206
- Xiaomi Miio integration
PROBLEM:
I can add Xiaomi Smart WiFi Socket using Xiaomi Miio integration. Token is correctly extracted and added to the setup. However, switch icon is not active, is greyed out and can’t be used.
I tried to remove/delete the Xiaomi Miio integration in order to delete device. Integration and switch were added again but nothing changes, problem persist.
I also have HA instance for testing purposes and in this instance Xiaomi Smart WiFi Socket can be used correctly, without the problem described above.
That points out that device setup is somehow corrupted in the device database.
QUESTION:
Is there anyway to manually delete this device from the database?
As far I could see, HA does not really support device database editing. But I can’t reinstall whole HA in order to fix issue with only one device.
Any advice or help is appreciated.
Alex
