I have a Xiaomi aqara switch that worked fine while ago with both Xiaomi Gateway and the Nortek stick. I am aware that the new HA is not recognizing the switch clicks. Recently due to my setup change - QNAP NAS>> Virtual Machine (8 GB RAM, 40GB HD)>> HASS OS (core version 2021.2.2, OS version version 5.11) >> Sonoff Zigbee bridge flashed with Tasmota - 6.7.8, I am able to capture only the switch power and not the clicks. I added “all events” node on node red and it is able to capture the clicks but under an “unidentified entity” How do I fix this?
Below is the debug logs when I press the switch. I get three events
- Pressing the switch - 2 events
- Releasing the switch - 1 event
How do I change the entity_id? How are you all fixing this issue? Thank you.
R
2/27/2021, 9:25:08 AMnode: 77ffaa0c.9700e4zha_event : msg.payload : Object
object
event_type: “zha_event”
entity_id: undefined
event: object
device_ieee: “00:15:8d:00:01:e8:6d:ec”
unique_id: “00:15:8d:00:01:e8:6d:ec:1:0x0006”
device_id: “7e5e5c96a396f3d1953505ae46979aeb”
endpoint_id: 1
cluster_id: 6
command: “click”
args: object
click_type: “single”
origin: “LOCAL”
time_fired: “2021-02-27T14:25:09.003056+00:00”
context: object
parent_id: null
user_id: null
2 second event
object
event: object
endpoint_id: 1
cluster_id: 6
command: “attribute_updated”
args: object
attribute_id: 0
attribute_name: “on_off”
value: true
origin: “LOCAL”
time_fired: “2021-02-27T14:25:09.003154+00:00”
context: object
parent_id: null
user_id: null
- switch release
2/27/2021, 9:26:41 AMnode: 77ffaa0c.9700e4zha_event : msg.payload : Object
object
event: object
endpoint_id: 1
cluster_id: 6
args: object
attribute_id: 0
value: false
origin: “LOCAL”
time_fired: “2021-02-27T14:26:42.065093+00:00”
context: object
parent_id: null
user_id: null
