But if I use this numeric state trigger only work if the temperature changed from 19 to 18.9
but if the temperature alredy 18 will never trigger this automation.
Thats why I want to use this sensor.
I know, I just found some issues with my tado sometines not heating and sometimes setting the wrong temperature… For some reason since I do both things, It has never made that mistake again.
Have tado thermostat in my living room and have xiaomi temp sensor in my bedroom.
In the living room have fireplace and the thermostat not turn the heating on too much. Soo my bedrom getting cold. I want that If my bedrom temp below 19 start the heating on higher temparature untill in the bedrom temp again above 19 and after stop heating. But I need this only between 01:00 - 05:30
The problem is If the temp in my bedroom before 01:00 below 19 the automation never will be triggered and the room very cold on the morning. I hope it is understand what I write
It isn’t good for me because this: “The problem is If the temp in my bedroom before 01:00 below 19 the automation never will be triggered and the room very cold on the morning.”
it checks at 1am. In combination with the conditions it checks to see if the temperature is already low at at that time. It does do what you want. Try it.
