So I have integrated the Xiaomi gateway (works fine, can set alarms etc), and connected the Temp Sensor to Mi Home, but it still doesnt show up in HA.
Any idea what I can do?
which temp sensor?
the first is supported in the app, but I dont think is supported in HA out of the box.
The other two use the gateway…and are supported.
Its the second one - any idea why it doesn’t show up in HA?
thanks
what integration are you using for the hub? there are two out of the box, and others…
I am using the Xiaomi Miio integration (standard from HA)
looking at https://www.home-assistant.io/integrations/xiaomi_miio/ they are not suppotred on this integration.
I’m using the other one
Aaah, and which one is that?Couldnt find anyone else than this…
Thanks!
