Xiaomi Temp sensor support
I have the Mijia temp sensor but doesn’t look to be supported.
Does anyone have a gearbest Xiaomi temperature sensor link that is supported in Home Assistant?
I got two Mija temp sensors working im my HA just fine. Can you specify which one you’re using?
Just a side note: i assume you have the Xiaomi gateway?
these are the bluetooth ones at https://www.home-assistant.io/components/mitemp_bt/ - likely Richard hasn’t put the mac address in the correct format.
Hi sorry,
got it working eventually. Turns out Jon was correct and i didn’t add the : into the mac address. Once i did that it worked like a treat.
