Did an upgrade of Valetudo to latest version 2021.02.0 on my 1st Gen vacuum and many things related to showing map were not working anymore and required many changes in HA configuration. I spent a lot of time on this, so sharing result to save some time for others.
I managed to get vacuum card working again plus I now have zone cleanup I always wanted.
Approach I described earlier is now obsolete. Everything now happens via MQTT instead of REST as before.
On vacuum setup Valetudo MQTT settings with “Homeassistant Map Hack” turned off.
In HA config add MQTT vacuum:
vacuum:
- platform: mqtt
schema: state
supported_features:
- start
- pause
- stop
- return_home
- battery
- status
- locate
- clean_spot
- fan_speed
- send_command
command_topic: "vacuum/servantess/command"
state_topic: "vacuum/servantess/state"
send_command_topic: "vacuum/servantess/custom_command"
set_fan_speed_topic: "vacuum/servantess/set_fan_speed"
fan_speed_list:
- min
- medium
- high
- max
Install ICantBelieveItsNotValetudo HA addon and configure accordingly. This addon will generate map image received from vacuum on
map_data
MQTT topic and publish it onmap
topic for your camera. -
Add MQQT camera entity for ready map:
camera:
- platform: mqtt
topic: vacuum/servantess/map
- Finally update Lovelace card. Mine looks like that:
- type: custom:mod-card
title: Servantess
card:
type: picture-elements
image: /local/images/transparent_background.png
style: |
ha-card {
--primary-text-color: white;
background-color: #155c9d;
font-size: 1.3rem;
font-style: bold
elements:
- type: image
entity: vacuum.servantess
camera_image: camera.servantess_map
style:
top: 30%
left: 50%
width: 100%
- type: icon
icon: mdi:home
style:
top: 90%
left: 20%
tap_action:
action: call-service
service: vacuum.return_to_base
service_data:
entity_id: vacuum.servantess
- type: icon
icon: mdi:play
style:
top: 90%
left: 35%
tap_action:
service: vacuum.start
service_data:
- type: icon
icon: mdi:deathly-hallows
style:
top: 90%
left: 50%
tap_action:
service: vacuum.send_command
service_data:
command: 'zoned_cleanup'
params:
'zone_ids': ['85312723-5b9e-4d45-9d33-09aaadc3ee9d']
- type: icon
icon: mdi:stop
style:
top: 90%
left: 65%
tap_action:
service: vacuum.stop
service_data:
- type: icon
icon: mdi:crosshairs-gps
style:
top: 90%
left: 80%
tap_action:
service: vacuum.locate
service_data:
- type: state-label
entity: sensor.servantess_state_label
style:
bottom: 12%
left: 1%
color: rgb(255, 255, 255)
transform: translate(0%,-50%)
pointer-events: none
text-shadow: 1px 1px black
font-family: Trebuchet MS
font-size: 90%
font-weight: bold
opacity: 0.8
- type: state-label
entity: sensor.servantess_cleanup_count_label
style:
bottom: 12%
right: 1%
font-size: 90%
font-weight: bold
opacity: 0.8
When verified it works cleanup related outdated stuff.
