Is there a thread for this card?
I have a Neato B6 and I can’t get it to show the Cleaning stats (Cleaned Area and Cleaning time).
Hello, I am thinking of getting myself a Xiaomi Viomi v3. Anyone know if it would be compatible with Home Assistant and/or the Xiaomi Mi Robot Vacuum integration?
HI @Hellcube can you confirm which integration you use for the vacuum ? miio2 ?
I was able to do some integration you do but not all
like LED, locate seems not working on my vacuum styj02ym
Also all infos like filter, mop not show information
Thanks for your help
i have used miio2.
Hello comunity.
I cannot manage to launch the vacum script with the card.
Here is my script:
salle_a_manger:
alias: test
icon: mdi:table-chair
sequence:
- data:
command: app_zoned_clean
params:
- - 23081
- 20668
- 28131
- 27218
- 1
entity_id: vacuum.xiaomi_vacuum_cleaner
service: vacuum.send_command
And here th code for de card:
actions:
- icon: 'mdi:table-chair'
Service: script.00000000000001
- icon: 'mdi:silverware-fork-knife'
service: script.Cuisine
- icon: 'mdi:shoe-formal'
service: script.Couloir
- icon: 'mdi:sofa'
service: script.salon
entity: vacuum.xiaomi_vacuum_cleaner
stats:
cleaning:
- attribute: cleaned_area
subtitle: Cleaning area
unit: m2
- attribute: cleaning_time
subtitle: Cleaning time
unit: minutes
default:
- attribute: filter_left
subtitle: Filter
unit: hours
- attribute: side_brush_left
subtitle: Side brush
unit: hours
- attribute: main_brush_left
subtitle: Main brush
unit: hours
- attribute: sensor_dirty_left
subtitle: Sensors
unit: hours
type: 'custom:vacuum-card'
But when i click the button nothing happen.
Hi there!
Here is my Xiaomi Vacuum clean Card.
If you like it, it’s available here:
So what part is the code? It looks amazing but i can’t find it on the github @Abeksis
Hola.
Conseguiste arreglar el problema del valor del fan_speed.
Yo poseo el mismo problema.
Un saludo.
Link fixed (moved to pastebin.com old pastebin.pl is down).
Hello
I have a problem, it does not work until the end, the card does not work, the buttons and the selection of rooms, which may be caused by I did according to the instructions
Did You add this to You configuration.yaml?
input_select:
vacuum_room:
name: Choose a room
options:
- Which room to vacuum
- Room1
- Room2
- Room3
- Room4
so added and the buttons only work start, stop, pauza, go to Home
Friends! How to “geolocate” the vacuum cleaner in the form of a list if the coordinates of the rooms are known?
For example, if the robot is in zone [11111, 22222, 33333, 4444, 1] while cleaning, the message “Bedroom” is returned, [55555, 66666, 77777, 88888, 1] - “Living room”, etc.?
Great job @Hellcube.
Maybe its stupid question, but why I have black colour of font?
And same situation like others, not all integration worked for me.
Do You guys have some solution for that?
Im using black theme (custom) so the font color is changed to white as default.
If you use the standard theme it is black default.
You would have to add (color: white;) to your style…
Thank You @Hellcube
i noticed it after a while a changed color to white. But im strugling still with fan speed button and brushes % values. To be sure, You are using code that You posted here, You have styj02ym and You are using this GitHub - nqkdev/home-assistant-vacuum-styj02ym code to connect to it (maybe You fored it and changed something, or used from another source)? Because i dont know where I have error with that:(
Once again thank You for help.
@Hellcube
I have Xiaomi Vacuum Mop Pro / STYJ02YM i used your code and it looks amazing.
But I have problem with using “Choose room option” neverthless what I choose it starts cleaning whole flat. If i go to Configuration->Scripts and run single script It goes to selected room (had to test some numbers to get correct rooms but now it’s ok)
Also I am not sure but looks like 1,2,3 icons do nothing.
Edit: Ok I have managed this problem (propably wrong YAML formatting - no errors but problems).
Now it works
When I go to services and fill in:
service: Vacuum.send_command
Entity: vacuum.name
And as service data:
"entity_id": "vacuum.name",
"command": "reset_consumable",
"params": [main_brush_work_time]
This does work like a charm.
But I want to have a button in Home Assistant to perform this action, and I can’t get it to work.
This is my script:
vacuummainbrush:
alias: "Reset main brush"
sequence:
- service: vacuum.send_command
data_template:
entity_id: vacuum.name
command: reset_consumable
params: main_brush_work_time
So… What I did at this time to get this working:
Made a script in scripts.yaml:
vacuummainbrush:
alias: "vacuummainbrush"
sequence:
data_template:
"entity_id": "vacuum.sucker", # Don't mind my vacuum's name :)
And I did add this to my card:
type: horizontal-stack
cards:
- type: entity-button
entity: script.vacuummainbrush
icon: 'mdi:broom'
tap_action:
action: call-service
service: script.vacuummainbrush
This way you can have multiple entity-buttons to run the script next to each other.
