Xiaomi Vacuum continue to clean from status Pause
Hello all,
how can the cleaning progress continue in the status “pause”? If I use “Start”, cleaning starts from the front and also loses the information regarding room cleaning.
-> vacuum.start_pauseis not working.
It is possible by a command?
thanks in advance.
If I use start_pause it produces an error, however start after pause works for me (the vacuum says “resuming” and continues on). I have an S5, so maybe it differs by model.
I have as well the S5.
If I use start, the robot start to clean all.
How do you clean the room? By room number or coordinate X/Y
I’ve only cleaned rooms a couple of times with HA, as generally I clean the whole area. When I have, I used send_command with a room number, but I have not paused and tried to resume a room clean. Given for me start will resume pause once started, maybe the same send_command would resume a room clean.
