I tried to make automation for two cleaning sequences in a row (without intermediate docking), but vacuum seems to ignore any local commands whilst returning to a charger after the first run (although it answers “ok” in the miio debug-log). Same time “pause” command sent through cloud works just fine. Is it a platform issue/limitation?
it is because somebody programmed component like it. I will make PR today to ‘repair it’.
For now it is
if self.state == STATE_CLEANING:
await self._try_command(
"Unable to set start/pause: %s", self._vacuum.pause)
so you can only pause while cleaning
I sent PR https://github.com/home-assistant/home-assistant/pull/20620
Now it is just waiting. Hopefully they will merge it soon, so it can be released with HA 0.88
Thank you for this! Hope PR will be merged ASAP
One more question about vacuum.start_pause
service: how do you think, it’s inapplicable for xiaomi vacuums, or just not yet implemented? For now, executing causes this error:
2019-01-31 18:37:21 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 287, in _handle_service_platform_call
await getattr(entity, func)(**data)
AttributeError: 'MiroboVacuum' object has no attribute 'async_start_pause'
According to this https://github.com/home-assistant/home-assistant/blob/786d178364cf38c9ba19b126201f87ba7d71a727/homeassistant/components/vacuum/init.py
there are two types of vacuum devices - with states and without states.
Those without states has method async_start_pause and such service as well.
Those with state has divided services as start, stop, pause, return_to_base etc.
So just don’t execute it I guess
You have fully confirmed my own conclusions, thank you for your spent time!
