I have some xiaomi aqara vibration sensors, but can’t make them do what I want!
I use deConz, and the device battery is at 95%.
They’re visible in HA and seem fine, but:
- The vibration strength is updated very rarely. E.g. I’d assume it should be 0 when the device is stationary. It’s not. Sometimes it’s updated when I tap on the device, sometimes not.
- The temperature is off by a lot, and is updated very rarely. Right now it says that it’s 30 degrees in my home office, but other temp sensors says 21.
- The orientation: When the device is on a table, it’s [2, 1, 88] almost all the time. Isn’t it supposed to change when I rotate it?
The vibration sensor on/off and the tiltangle seem to work fine.
Are there any configuration parameters that I can set for this device? I know of the sensitivity setting, which seems to work.
Is it possible to configure devices from the deConz/phoscon gui?
