I use plugs with power monitoring for washer and dryer as well.
I tried the vibration sensors for that but that doesn’t worked at all.
I have this - it works, and my automation announces accurately when the washing machine or dryer are finished. However they don’t know if the door has been opened, and if the kids forget to turn off the device, it continues to announce…
I tried to use the vibration sensor to detect the door opening, but coulnd’t get it to work.
(and can’t use a magnetic relay switch, as the door is steel/magnetic!)
You don’t need a door sensor for that…
Create an automation that when power goes above, let’s say, 50 wats, then turns on a second automation.
This second automation is the one you say you already have, the one with the announcement. This one triggers, let’s say, when power has been below 3 watts for more than 2 minutes… When it triggers, its first action is to turn itself off, so it only makes one announcement.
Until the washing machine goes above 50 again, it won’t turn on the announcement automation again…
So not using vibration sensor, and because I can’t remember where i got the original, the package I’m using:
# Packages/Appliances #
# Customize #
homeassistant:
customize:
# binary_sensor.door_window_sensor_158d0001e73a83:
# friendly_name: Washing Machine Door
# icon: mdi:door
switch.plug_158d0002431039:
initial_state: on
icon: mdi:washing-machine
sensor.washing_machine_status:
# binary_sensor.door_window_sensor_158d0001e73bc5:
# friendly_name: Dryer Door
# icon: mdi:door
switch.plug_158d00024333bd:
initial_state: on
icon: mdi:tumble-dryer
sensor.dryer_status:
# Groups #
group:
washing_machine:
entities:
- switch.plug_158d0002431039
- sensor.washing_machine_status
# - binary_sensor.door_window_sensor_158d0001e73a83
dryer:
entities:
- switch.plug_158d00024333bd
- sensor.dryer_status
# - binary_sensor.door_window_sensor_158d0001e73bc5
# Inputs #
input_boolean:
disable_washing_machine_notification:
name: Disable Washing Machine Notification
initial: off
disable_dryer_notification:
name: Disable Dryer Notification
initial: off
input_select:
name: Washing Machine Status
options:
- Idle
- Running
- Finishing
- Clean
initial: Idle
dryer_status:
options:
- Idle
- Running
- Finishing
- Clean
initial: Idle
# Sensors #
# Sensors - Template #
sensors:
## Washing Machine Status
value_template: '{{ states.input_select.washing_machine_status.state}}'
friendly_name: 'Washing Machine Status'
## Washing Machine Power Usage
washing_machine_power:
value_template: '{{ states.switch.plug_158d0002431039.attributes.load_power|int }}'
friendly_name: 'Washing Machine Power'
## Dryer Status
dryer_status:
value_template: '{{ states.input_select.dryer_status.state}}'
friendly_name: 'Dryer Status'
## Dryer Power Usage
dryer_power:
value_template: '{{ states.switch.plug_158d00024333bd.attributes.load_power|int }}'
friendly_name: 'Dryer Power'
#### Lovelace-UI ####
## Washer Power Graph
washing_machine_load:
value_template: 'Power: {{ states.switch.plug_158d0002431039.attributes.load_power|int }}'
friendly_name: 'Washer Power'
unit_of_measurement: 'W'
## Washer Status
washer_status:
value_template: 'Washer: {{ states.input_select.washing_machine_status.state}}'
## Dryer Power Graph
dryer_load:
value_template: 'Power: {{ states.switch.plug_158d00024333bd.attributes.load_power|int }}'
## Dryer Status
clothes_dryer_status:
value_template: 'Dryer: {{ states.input_select.dryer_status.state}}'
# washer_door_status:
# friendly_name: Door
# entity_id: binary_sensor.door_window_sensor_158d0001e73a83
# value_template: >-
# {% if is_state('binary_sensor.door_window_sensor_158d0001e73a83', 'on') %}
# Open
# {% elif is_state('binary_sensor.door_window_sensor_158d0001e73a83', 'off') %}
# Closed
# {% endif %}
# dryer_door_status:
# entity_id: binary_sensor.door_window_sensor_158d0001e73bc5
# {% if is_state('binary_sensor.door_window_sensor_158d0001e73bc5', 'on') %}
# Open
# {% elif is_state('binary_sensor.door_window_sensor_158d0001e73bc5', 'off') %}
# Closed
# {% endif %}
# Automations #
automation:
## When power is detected, and the washing machine is not in
## the Running state, change the status of the washing machine
## to Running.
## The status check will ensure we don't try to put the state
## to Running each time the power level changes, and we're already
## in the Running state.
- alias: Set washing machine active when power detected
- platform: numeric_state
entity_id: switch.plug_158d0002431039
value_template: '{{ state.attributes.load_power }}'
above: 8
for:
minutes: 1
condition:
condition: or
conditions:
- condition: state
entity_id: sensor.washing_machine_status
state: Idle
- condition: state
state: Clean
- condition: state
state: Finishing
- service: input_select.select_option
entity_id: input_select.washing_machine_status
option: Running
## When the power drops, move the state of the washing machine to
## Finishing.
- alias: Set washing machine finished when power drops
below: 6
condition:
condition: and
conditions:
- condition: state
state: Running
option: Finishing
## Wait 1 minutes for us to be in the Finishing state before we
## decide the washing machine has finished. This way, if the
## washing machine is in between cycles and the power drops, we
## won't mark the washing machine cycle as finished too early.
- alias: Set washing machine clean after timeout
- platform: state
to: Finishing
for:
minutes: 1
condition:
condition: and
conditions:
- condition: state
state: Finishing
option: Clean
## When we turn off the power, reset the status back to
## idle, so we don't spam people that the washing machine has
## finished, and someone has already emptied it - assumes it is empty.
- alias: Set washing machine dirty when door opens
below: 3
for:
minutes: 1
condition:
condition: or
conditions:
- condition: state
state: Clean
- condition: state
state: Finishing
option: Idle
## Washing Machine Alerts
- alias: Send alert when washing machine is finished
- platform: state
to: Clean
for:
minutes: 1
- platform: state
entity_id: binary_sensor.someone_home
to: "on"
for:
minutes: 2
- platform: time_pattern
minutes: 5
condition:
condition: and
conditions:
- condition: time
before: '21:00:00'
after: '08:00:00'
- condition: state
state: "on"
- condition: state
state: Clean
- condition: state
entity_id: input_boolean.disable_washing_machine_notification
state: 'off'
- condition: template
value_template: >
{% if states.automation.send_alert_when_washing_machine_is_finished.last_triggered is not none %}
{% if as_timestamp(now()) | int - as_timestamp(states.automation.send_alert_when_washing_machine_is_finished.attributes.last_triggered) | int > 1800 %} true {% else %} false
{% endif %}
{% else %}
false
{% endif %}
- service: notify.google_assistant
message: 'The washing machine has finished and is ready to be emptied'
- service: notify.emailjonwork
## When power is detected, and the dryer is not in
## the Running state, change the status of the dryer
## to Running.
- alias: Set dryer active when power detected
entity_id: switch.plug_158d00024333bd
above: 10
condition:
condition: or
conditions:
- condition: state
entity_id: sensor.dryer_status
state: Idle
- condition: state
state: Clean
- condition: state
state: Finishing
entity_id: input_select.dryer_status
option: Running
## When the power drops, move the state of the dryer to
## Finishing.
- alias: Set dryer finished when power drops
below: 6
condition:
condition: and
conditions:
- condition: state
state: Running
option: Finishing
## decide the dryer has finished. This way, if the
## dryer is in between cycles and the power drops, we
## won't mark the dryer cycle as finished too early.
- alias: Set dryer clean after timeout
- platform: state
to: Finishing
for:
minutes: 1
condition:
condition: and
conditions:
- condition: state
state: Finishing
option: Clean
## When we open the dryer door, reset the status back to
## idle, so we don't spam people that the dryer has
- alias: Set dryer dirty when door opens
entity_id: sensor.tumbledryer_power_sensor #switch.plug_158d00024333bd
# value_template: '{{ state.attributes.load_power }}'
below: 0.2
for:
minutes: 1
condition:
condition: or
conditions:
- condition: state
state: Clean
- condition: state
state: Finishing
option: Idle
## Dryer Alerts
- alias: Send alert when dryer is finished
- platform: state
to: Clean
for:
minutes: 1
- platform: state
to: "on"
for:
minutes: 2
minutes: 5
condition:
condition: and
conditions:
- condition: time
before: '21:00:00'
after: '08:00:00'
- condition: state
state: "on"
- condition: state
state: Clean
- condition: state
entity_id: input_boolean.disable_dryer_notification
state: 'off'
value_template: >
{% endif %}
{% else %}
false
{% endif %}
message: 'The dryer has finished and is ready to be emptied'
Too long a day to work out how to change it as you suggest…
I really don’t understand why would I do all that for something that can be done with a 10% of that code and less hardware. I really think you overdid it
above: 50
- service: homeassistant.turn_on
entity_id: automation.send_alert_when_washing_machine_is_finished
below: 6
for:
minutes: 1
- platform: state
to: on
for:
minutes: 2
minutes: 5
condition:
condition: and
conditions:
- condition: time
before: '21:00:00'
after: '08:00:00'
- condition: numeric_state
entity_id: sensor.washing_machine_power
below: 6
for: '00:01:00'
- condition: state
state: on
for: '00:02:00'
- wait_template: "{{ state_attr('switch.plug_158d0002431039', 'load_power')|float < 0.5 }}"
- service: homeassistant.turn_off
Thank you for comforting me everyday in my choice of NodeRed for my automotions !
I thought exactly the same, it’s crazy to do that in YAML, yet how easily would that fit in Node Red
I guess it becomes better when you get used to it, but what I dislike about yaml is the number of lines to do so few things… you’ll need to scroll at least on 3 or 4 full screens to have a global picture while this will fit in 15-25 nodes on Node Red that will easily be displayed on one screen.
Thanks Home Assistant to provide so many ways to do things !
In my defence, I used someone else’s code, and it worked for what I wanted (plus the code does both washing machine and dryer, so twice as many lines…).
In addition, the package also sets up up some graphs which were useful for checking the power values, and sets a status flag for running, idle etc, so your code whilst doing the notification isn’t a direct replacement. (not complaining here btw)
never got to the point of installing it, so I dont know what I’m missing.
And as always with HASS, multiple ways to do something…
No need to defence sorry… my mistake, you are absolutely right…
If you happen to have some time one day, you might take a few hours to try Node Red out.
It’s very powerfull and has some advantages : it is very grafical, it does what you see, and you see the node values et their timestamp, very usefull to understand how things move in a flow. And as I said you can define complex algorithms and keep a global picture on one single screen where you would have to use 3, 4 or 5 screen is yaml for instance.
It has also has some inconvenient. For my point of view, the 2 main inconvenients of Node Reds used with HA are :
I will personally have to do things in the reverse way and take time to learn about core yaml automotions, especially since Blueprints have been added, so I will be able to take the best form both worlds.
I want to try a vibration sensor to capture the moment that the storm is near and you need to turn off the main switch of my house. I plan to monitor the readings of the sensor attached to the window pane. (When lightning is nearby - the windows vibrate well)
Has anyone done this?
My history_stats sensor won’t count. It stays at 0. I do detect movement. I have the vibration sensor connected through homekit controller. What could the problem be?
Can you post your yaml config?
I’ve got the following in the configuration.yaml.
I’ve made a test lovelace panel. See picture. It detects when there is movement, but it doesn’t count up.
I’ve found the solution. I had to change ‘state’ to ‘on’ and not ‘vibrate’. It seems to work now.
Can you share your configuration? My vibration sensor is laying around doing nothing…
I made this automatisation:
alias: Wasmachine einde
description: Melding als wasmachine gedaan is
I also made this sensor:
I’m a real amateur, so if you find anything to make it better, let me know. The problem with this is that it doesn’t recognize the difference between a hot wash and a was at 30°. A hot was takes much longer, so I have to take the time of the longest wash.
Would like to know your configuration too if possible.
