Xiaomi wall switch
I have a problem.
I have a xiaomi gateway and wall Switch double with neutral.
The home assistant not discovered the wall switch, but others things is good. (temperature sensor, door sensor)
Yes I added it. The door sensor and the thermometer are working, but the wall switch does not.
Sorry I deleted my post after re-reading (already done what i advised)
That’s a strange one as the component page for gateway mentions the switch being compatible. I was actually going to order one from Alliexpress to see what they are like and if I wanted to go that direction with all lights.
hopefully someone can chime in that has it integrated.
