Hi kind people of the forums! I have a somewhat weird situation regarding a xiaomi wireless wall switch which is this little thing here.
What applies is:
I have configured my switch, in customization.yaml as such:
binary_sensor.wall_switch_158d0001576456:
friendly_name: Bedroom slave switch
device_class: connectivity
hidden: true
Then I have coded my automation, in my automation.yaml as such (which works OK - I am not here to ask help on the automation code):
- alias: Time-based bedroom light toggle
- platform: event
event_type: click
event_data:
entity_id: binary_sensor.wall_switch_158d0001576456
click_type: single
service_template: >
{% if is_state('switch.wall_switch_ln_158d0001c2b51e', 'on') or is_state('light.georges_bedside_lamp', 'on') or is_state('light.vivians_bedside_lamp', 'on') -%}
homeassistant.turn_off
{% elif (now().hour | int > 8) and (now().hour | int < 19) %}
homeassistant.turn_on
{% elif (now().hour | int > 18) or (now().hour | int < 9) %}
light.turn_on
{% endif %}
data_template:
entity_id: >-
{%- if is_state('switch.wall_switch_ln_158d0001f987c2', 'on') or is_state('light.floor_lamp', 'on') or is_state('light.table_lamp', 'on') -%}
group.bedroomlights
{%- elif (now().hour | int > 8) and (now().hour | int < 19) -%}
group.bedroomambientlights
{%- elif (now().hour | int > 18) or (now().hour | int < 9) -%}
light.bed_ambient_light
{%- endif -%}
And when firing the click event_type through the “Events” menu in Developer tools everything work like a charm.
THE PROBLEM:
When I am trying to actually use the automation in every-day life by hitting the wall switch it doesn’t work. The reason it doesn’t work according to HA’s log is the following:
Unsupported click_type detected: long_click
10:03 AM components/binary_sensor/xiaomi_aqara.py (WARNING)
From what I’ve seen on the documentation this type of aqara binary_sensor only reports ‘click’. So I cannot understand how it manages to report a long_click. Could it be a bug?
Thanks for any help.
Widely appreciated.
