I have the xiaomi wifi bed side lamp (wifi ble version).
all is working good but there is something i can’t do with it.
In the yeelight app, there is many possibilities, and one of them is a preconfigured mode named night mode
(it’s a kind of warm orange with a low brightness).
I would like to set up exactly the same color with hass, but ???
I’ve check the attributes values when this mode is on and write it on a paper , i’ve try to set up the same attributes values, but the color is not the same.
I have investigate a little and what i’ve discovered is that in the yeelight app, when you choose this night mode, and after you go to the color tab, the color of the lamp is changed and take the same color that if you manually encode the attributes value writed on the paper before.
it’s like the color of the night mode
is under the range of attributes value.
it’s not easy to explain, but if someone have the same lamp, it’s easy to test.
- put the night mode on with yeelight app
- see the color of your lamp
- go to home assistant and see the attributes value
- go to the tab color of yeelight app
==> your lamp color have changed, but not you attributes value,
==> if you make a script who set up these value, the result is the second color, not the night mode color
anyone have an idea ?
regards
