To get rid of the error you can manually add the two lines of code to the yeelight.py But as @abmantis wrote it’s safe to ignore the warning.
hi all, not sure if my issue is related to this component and to the fix suggested above:
I have a white yeelight connected to HASS - before updating from 0.50.1, I had the effects dropdown available and had no issues using the toggle button to switch on and off the yeelight.
since updating to 0.52.1, I no longer have the effects option and the only way to switch off the light is to move the brightness slider back to the zero position.
any advice?
Rebooting the raspberry pi and power cycling the light fixed the same problem for me.
ah - ok, will try it out.
i’ve rebooted the pi a number of times as thought that there was an issue with the way i’d setup the config.yaml
haven’t cycled the light yet…
Not sure if it will help but just in case, use the yeelight app to make sure the lights are running the latest firmware.
thanks, checked that too.
they are up-to-date.
when in doubt - reboot…
thanks for the help all!
Hi Guys!
I want to swich off my yeelight LED strip with my Xiaomy wireless switch.
Can you help me what is the action? I have the trigger:
- alias: Stairs LED off
platform: event
event_type: click
event_data:
entity_id: binary_sensor.switch_15xxxxxxxce
click_type: single
But… I don’t know what is the correct action for Turning off my Yeelight LED strip. Can you help me?
Sorry i don’t have yeelight led strip.
But must be something like this:
- service: light.turn_on
entity_id: light.gateway_light_f0b4XXXXXX
brightness: 255
rgb_color: [4,26,255]
But to be sure, i recomend you enter to your home assistant options and go to state and see what you see in your yeelight led strip, and change the entity_id of my example by yours
Thank you!
I think this will work for me than:
platform: event
event_type: click
event_data:
entity_id: binary_sensor.switch_15xxxxxxxxce
click_type: single
service: light.turn_off
entity_id: light.yeelight_strip_28xxxxxxxxca
transition: 5
Did you figured what the problem was with your LED strip?
I’m having the same issue as I can turn on/off and even can set an effect however, I can’t control the colors of the LEDs.
I’m getting frustrated for a while now trying to figure this out…!
I have the same problems
Hi! In the configuration.yaml add the model to the yeelight config. If the strip is the version 2, add as it was the version 1. It worked for me
Thanks. Was looking for a solution to this very problem and adding
model: strip1
to my config for the light strip fixed it.
