I have Xiaomi GW integrated via HomeKit. GW version is ZNDMWG02LM. On GW i have few sensors - temp, water leak, door sensor and everything works and shows on HA. Few days ago I bought Xiaomi ZigBee plug ZNCZ04LM. I pair it with GW and it shows in Mi Home app but it doesn’t shows in HA. Is there something that I can check, do? I tried to unpair and pair again.
Sometimes I have found the entity id in HA is “unexpected”, like “switch.ver-long-identifier”, so I don’t find it in Developer Tools and think it hasn’t worked. However it is in in the list of entities on the Integration page - have you checked there?
No I cant find it. No any new strange entity
Hello I have the same GW, how did you do to have the GW & the sensors attached in home assistant ?
I integrated like Home Kit Controler. It was find on my local network and I used code for Home Kit that is under the GW
Strange mine is not discovered… Did you setup other things before ?
And you setup the gateway on which country ?
Ok it’s working it was just because my gateway was yet paired in the apple home.
I removed the bridge in apple home and it appears in home assistant.
