Since we have a rather large presence of Xiaomi in the platform are there anyone interested in integration of the Xiaomi cookers (it says “rice” but it much more then just that) to the HA?
I did. Probably one of most useful purchases of kitchen appliances. All you have to do is figure out you favorite dish load it up in the morning and by the moment you arrive you have it done and hot (keep worm feature is there as well).
I would implement the component if somebody provides some support/testing. The needed steps:
Install the Mi Home app and add the xiaomi device. This will download a device plugin.
Please provide a copy of the mi home plugin. cp. Xiaomi Humidifier support
You don’t need a rooted android device. A emulator is sufficient or a android backup of a non-rooted device.
I will decompile the android app and provide the used API calls/methods
A Home Assistant isn’t needed at the moment. We need a python setup later on. It’s part of a typical OSX install as far as I know. You should be able to install python-miio by:
Yeah it rather wide. But some name are in Russian so please ping me if you need any support with integration.
It seems it similar to purifier so we need to extract token, is it a same procedure?
There are additional ways to retrieve the token. python-miio provides a command line tool to extract the token from a iOS backup and/or android backup.
