Xioami cooker integration
do you still need help or @bachulator alone is enough? I m not understanding this mirobo command and where u can run it.
@LaFed I would be happy if some more people are involved. Did you extract your access token? If yes I will explain the python-miio install and using the included command line tool mirobo.
As much people get involve as much more chance of achieving something we get.:+1:
ok… will install nox when i get home in an hour and try extracting it
ok managed to install nox player and mihome 5.0.15 but when extracting, it says there’s something wrong and way too small… I did enable USB debugging and enable backup (with no password) within nox…
The process described rather well here.
So you need adb on host and then somehow forward usb for debugging, i guess.
After numerous try, I decided to give up and go to ios route… I now managed to get the ztoken… Please proceed on the next step on how I can continue…
@LaFed What’s the length of the token? If it’s longer than 32chars it needs to be decrypted first. Which operation system (linux, mac, windows) do you use?
@syssi 96 chars… im on windows
Then you go to the good way :slight_smile:
Now you need to decrypt these 96 chars.
look this: https://community.home-assistant.io/t/xiaomi-gateway-integration/8213/3103?u=syssi
cool… im done and got my key… what’s next?
That’s the next step:
  1. Install python >=3.5
  2. Install pip
  3. Install python-miio via pip: pip3 install python-miio
You should use this how to: https://pip.pypa.io/en/stable/installing/#do-i-need-to-install-pip
@syssi i think im done… hit me with next step
The python-miio library contains a command line tool called mirobo. Are you able to execute the tool at the command line? You must know the path may be.
mirobo --ip <ip> --token <token> info
Does your cooker respond? :slight_smile:
yup… not sure what info is sentive though
chunmi.cooker.normal2 v1.2.8 (mac address) @ 192.168.1.30 - token: (my token)
mirobo --ip --token raw_command get_prop '[“func”, “menu”, “stage”, “temp”, “t_func”, “t_precook”, “t_cook”, “setting”, “delay”, “version”]'
Sending cmd get_prop with params [‘func’, ‘menu’, ‘stage’, ‘temp’, ‘t_func’, ‘t_precook’, ‘t_cook’, ‘setting’, ‘delay’, ‘version’]
[‘waiting’, ‘0001’, ‘null’, ‘31’, ‘60’, ‘-1’, ‘60’, ‘1407’, ‘05040f’, ‘00030017’, ‘0100’, ‘ffffffffffff011effff010000001f1f’]
mirobo --ip --token raw_command get_prop '[“all”]'
Sending cmd get_prop with params [‘all’]
Perfect! You are able to send instructions now. Could you provide the output of:
mirobo --ip <ip> --token <token> get_temp_history "[]"
I will try to reverse engineer the parameters of the other commands. May be I need some support because recipes can be downloaded from a web platform and transferred as hex value to the cooker.
Usage: mirobo [OPTIONS] COMMAND [ARGS]…
Error: No such command “get_temp_history”.
Could you collect the different values of the property “func”? May be cook some stuff. Query get_prop ["all"] periodically and provide the output with timestamps. :slight_smile:
Ups! I meant:
mirobo --ip <ip> --token <token> raw_command get_temp_history "[]"
