Xioami cooker integration
Does anyone know if it is possible to set the cooking profile time? for example, when I start the steam mode, it automatically goes to 30 minutes. Would it be possible to run it 20 minutes or 45 minutes? knowing that this option is possible from the application.
Best regards
Did you manage to connect this model?
I’m a mid-level developer, acquiring more knowledge to start helping in open sources. Having said that, it’s very cool to read about the development progress done here.
I’m searching for cooking equipment and analyzing the integration with HA, that’s how I arrived here.
Nonetheless, thank you all for that awesome discussion!
I am having the same problem. I would like to buy one, but really dont understand which one to buy, that is definitly supported by syssi
Hey
So this is the one i bought for reference
Note that its no longer in stock but im sure you can find something similar on aliexpress.
Not responsible if it does not work as im not sure if the new ones are build differently
Also be sure to check the voltage as its 220v, so you might need a converter
Thank you for your answer.
I was looking for a smaller and cheaper one :sweat_smile:
Something like this: https://aliexpress.com/item/4000096426315.html
But It wont be supported, right? :frowning:
Model number seems to be DFB201CM
Hmm hard to say.
I do not see it in the documentation
If you are thinking of buying then returning if it does not work be very wary
It might be a hassle and costly to send it back
I just bought one so we’ll see how it integrates soon-ish
it can cloud integrate using GitHub - al-one/hass-xiaomi-miot: Automatic integrate all Xiaomi devices to HomeAssistant via miot-spec, support Wi-Fi, BLE, ZigBee devices. but its pretty bad options for the rice cooker are limited so the integration cannot do much with it
This component: hass-xiaomi-miot uses the miot-spec protocol. If there are not enough attributes or methods in the device’s miot protocol definition, the component cannot fully support it.
Full integration is possible using GitHub - sschirr/xiaomi_cooker: Xiaomi Mi Electric Rice Cooker integration for Home Assistant
I do have an issue that state, rice_id, taste, taste_phase, stage_name and stage_description remain Unknown in my case
Is there any easy way to run favorite profile? I see that there is a sensor but it contains only 3 characters while profile is much longer.
Thanks in advance!
Hi, I’m new to Xiaomi rice cookers and it’s very hard for me to understand their models. I can’t find a model and be sure that it could be compatible with GitHub - sschirr/xiaomi_cooker: Xiaomi Mi Electric Rice Cooker integration for Home Assistant or GitHub - syssi/xiaomi_cooker: Xiaomi Mi Electric Rice Cooker integration for Home Assistant . I am in France. I found multiple models on Aliexpress but the models don’t match the format on the readme of both modules. Could someone help me to find one ?
I found this https://fr.aliexpress.com/item/1005001785817433.html, but it doesn’t look to be connected. But I found other websites saying it was connected so I’m unsure.
I found this one too https://fr.aliexpress.com/item/1005004077393519.html but I can’t figure out what model it is.
Could someone help ?
Thanks in advance
This one seems very similar to mine
The form + the specs are the same from what i can see
Again please do your due diligence by asking the model number to make sure
Any chance of this component being extendable to support the Xiaomi/Tokit Smart Induction Hob/Cooktop?
I’d be happy to supply any necessary data. Without Home Assistant support, it’s a pretty limited cooker (due to very restricted controls within the Xiaomi Home app). HA plus this cooker, could provide an amazing smart device.
It works great in HA.
I used Xiaomi Miot Auto (HACS).
You can get all information for programming here: joyami Smart Rice Cooker S1 - 产品规格 - Xiaomi Miot Spec
