This is the first draft of the device support:
Cool. Let me know when you need a tester.
P.S. One russian word in source Отмена = Cancel.
Will come back with get_temp_history later today.
I’ve a question about this state. The property t_precook
has the value 750 here. Did you schedule the next cooking already? Is it 750 minutes = 12,5 hours?
according to the manual, maximum keep warm time is 12 hours… after that it will auto off
mirobo --ip [IP] --token [TOKEN] raw_command set_menu '[“0001E101000000000000800200A00069030103730000085A020000EB006B040103740000095A0400012D006E0501037400000A5A0401FFFF00700601047600000C5A0401052D0A0F3C0A1E91FF820E01FF05FF78826EFF10FF786E02690F0DFF826EFF691000FF826EFF69100069FF5AFF00000000000081E9”]'
Sending cmd set_menu with params [‘0001E101000000000000800200A00069030103730000085A020000EB006B040103740000095A0400012D006E0501037400000A5A0401FFFF00700601047600000C5A0401052D0A0F3C0A1E91FF820E01FF05FF78826EFF10FF786E02690F0DFF826EFF691000FF826EFF69100069FF5AFF00000000000081E9’]
[‘ok’]
mirobo --ip [IP] --token [TOKEN] raw_command get_prop '[“all”]'
Sending cmd get_prop with params [‘all’]
[‘running’, ‘0001’, ‘01000000ff’, ‘031e1112’, ‘58’, ‘-1’, ‘60’, ‘1407’, ‘05060f’, ‘00030017’, ‘0100’, ‘13281323ffff011effff010001012f17’]
mirobo --ip [IP] --token [TOKEN] raw_command get_temp_history "[]"
Sending cmd get_temp_history with params []
[‘161515161c242a3031302f2eaa2f2f2e2f’]
After 10 minutes:
[‘running’, ‘0001’, ‘02000000ff’, ‘031e1112’, ‘48’, ‘-1’, ‘60’, ‘1407’, ‘05060f’, ‘00030017’, ‘0100’, ‘13281323ffff011effff010002013f1e’]
[‘161515161c242a3031302f2eaa2f2f2e2f2e302f2e2d302f2f2e2f2f2f2f343a3f3f3d3e3c3d3c3f3d3d3d3f3d3d3d3d3e3d3e3c3f3f3d3e3d3e3e3d3f3d3c3e3d3d3e3d3f3e3d3f3e3d3c’]
Seems to be concatenated hex values, or?
After ~15 minutes:
[‘running’, ‘0001’, ‘07000000ff’, ‘031e1112’, ‘28’, ‘-1’, ‘60’, ‘1407’, ‘05060f’, ‘00030017’, ‘0100’, ‘13281323ffff011effff01000701595f’]
[‘161515161c242a3031302f2eaa2f2f2e2f2e302f2e2d302f2f2e2f2f2f2f343a3f3f3d3e3c3d3c3f3d3d3d3f3d3d3d3d3e3d3e3c3f3f3d3e3d3e3e3d3f3d3c3e3d3d3e3d3f3e3d3f3e3d3c3f3e3d3c3f3e3d3c3f3f3d3d3e3d3d3f3f3d3d3f3f3e3d3d3d3e3e3d3daa3f3f3f3f3f414446474a4e53575e5c5c5b59585755555353545454555554555555565656575757575858585859595b5b5c5c5c5c5d5daa5d5e5f5f606061’]
after 55 minutes:
[‘running’, ‘0001’, ‘0a000000ff’, ‘031e1112’, ‘5’, ‘-1’, ‘60’, ‘1407’, ‘05060f’, ‘00030017’, ‘0100’, ‘13281323ffff011effff01000a005163’]
[‘161515161c242a3031302f2eaa2f2f2e2f2e302f2e2d302f2f2e2f2f2f2f343a3f3f3d3e3c3d3c3f3d3d3d3f3d3d3d3d3e3d3e3c3f3f3d3e3d3e3e3d3f3d3c3e3d3d3e3d3f3e3d3f3e3d3c3f3e3d3c3f3e3d3c3f3f3d3d3e3d3d3f3f3d3d3f3f3e3d3d3d3e3e3d3daa3f3f3f3f3f414446474a4e53575e5c5c5b59585755555353545454555554555555565656575757575858585859595b5b5c5c5c5c5d5daa5d5e5f5f60606161616162626263636363646464646464646464646464646464646464646364646464646464646464646464646464646464646464646464646464aa5a59585756555554545453535352525252525151515151’]
Keep worm mode:
[‘autokeepwarm’, ‘0001’, ‘1000000000’, ‘031e1112031e’, ‘0’, ‘1090’, ‘60’, ‘1007’, ‘05060f’, ‘00030017’, ‘0100’, ‘13281323ffff011effff010000004e61’]
[‘0’]
Could you provide some additional translations?
cooking_stage_desc_k1:
Регулировать температуру, давления, для размягчения риса
Длительный нагрев, рис поглощает воду, становится более насыщенным и сладким
Держите температуру высокой, рис любит равномерное тепло
Высокотемпературный пар, рис кристально чистый, запечатанный и сладкий
Подогрев риса, раскроет весь его вкус
cooking_stage_desc_k2:
Регулировать температуру, для смягчения риса
cooking_stage_names_k1:
Быстрый разогрев
Температура воды
Кипячение
Давление
Тушеный рис
cooking_stage_names_k2:
Температура воды
Кипячение
Горячий и клейкий
recipe_cooking_finish:
Завершено
Выпечка хорошая.
Подогрев
Хорошее брожение
Хорошее приготовление
Хорошее рагу
Хорошо
Каша закипела, хорошо
recipe_is_cooking:
Are
Делаем
Выпечка
Глиняный горшок
Брожение
Вареный
Тушеное мясо
Прекрасный рис
Быстрое приготовление риса
Tried to do my best, but sometimes rather hard to do without context. After all it is Chinese-to-English-to-Russian-to-English translation. What really could go wrong ?
So here it is:
Регулировать температуру, давления, для размягчения риса = Adjusting temperature and pressure to soften the rice
Длительный нагрев, рис поглощает воду, становится более насыщенным и сладким – Longer heating, rice is absorbing water to be more soft and sweet
Держите температуру высокой, рис любит равномерное тепло – Keeping the temperature high, rice is absorbing the heat
Высокотемпературный пар, рис кристально чистый, запечатанный и сладкий – High pressure steam to seal the flavor of sweet taste.
Подогрев риса, раскроет весь его вкус – Reheat the rice to open its taste.
Регулировать температуру, для смягчения риса - Adjust the temperature to soften rice.
Быстрый разогрев – Quick reheating.
Температура воды – water temperature
Кипячение – boiling
Давление – pressure
Тушеный рис - Braised rice
Горячий и клейкий – Hot and sticky
Завершено – Completed
Выпечка хорошая. - Backing
Подогрев – Reheating
Хорошее брожение – (Well/Good?) fermentation
Хорошее приготовление - (Well/Good?) cooking
Хорошее рагу – (Well/Good?) Stew
Хорошо – (Well/Good?)
Каша закипела, хорошо – porridge is boiling, (Well/Good?)
Делаем – doing/maing/cooking?
Выпечка – Cake/bakery/backing
Глиняный горшок
Брожение – Fermentation
Вареный – Boiled
Тушеное мясо – Braised meat
Прекрасный рис – Perfect rice
Быстрое приготовление риса – Quick rice cooking
May be we should extract another (english) version of the Mi Home plugin.
I will let you know if I will manage to get one.
Cool! The device implementation for python-miio is almost feature complete!
Just an idea, I wonder what would happen if you would install the plugin to emulated android with mihome and then change default language to english and restart the app will make attempt to open device? Will it download english apk?
I don’t know. May be, yes!
Can you try to do this trick with this russian plugin (on your virtual device of cause), then probably you will endup with english plugin…
I cannot install the plugin because I don’t own the device.
But that the trick will the app check if you own the device when you change the default language or download all addons blindly? IF blindly we might get the english apk
I got your point. I will give it a try.
Hi @Syssi,
I see changes related to the device support are merged with mirobo. Whant your assumption when we could see integration with HA? Supporting material?
It will need a few more weeks. The HA component is still far away.
Any news on this component?
This is the current development version: https://github.com/syssi/xiaomi_cooker
You should group the sensor to a card by:
rice_cooker:
control: hidden
entities:
- sensor.xiaomi_cooker_duration
- sensor.xiaomi_cooker_remaining
- sensor.xiaomi_cooker_mode
- sensor.xiaomi_cooker_stage_name
- sensor.xiaomi_cooker_stage_description
- sensor.xiaomi_cooker_rice_id
- sensor.xiaomi_cooker_state
- sensor.xiaomi_cooker_taste
- sensor.xiaomi_cooker_taste_phase
- sensor.xiaomi_cooker_temperature
- sensor.xiaomi_cooker_favorite
- sensor.xiaomi_cooker_menu
