XKC-Y25 multiple sensors on Wemos D1 mini
Hi all,
I am trying to get two xkc-y25 sensors to work on an esp8266 Wemos D1 mini, when using one sensor on GPIO16, it works, but adding a second sensor is proving difficult, below is my yaml, anyone have a clue how I can get the second sensor working? I am not using any external resistors. Help is appreciated. Thanks.
esphome:
  friendly_name: Tank
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: x
ota:
  password: "69f53bdaab9d3ce6df99191d527a611a"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Tank Fallback Hotspot"
    password: "w4Gsuwgxoepj"
captive_portal:
  # Example configuration entry
web_server:
  port: 80
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO16
      mode:
        input: true
        pulldown: true
    device_class: moisture
So I see only one sensor configured. Where is the config for the second sensor that doesn’t work? What are the symptoms?
I got it to work with the below code with two sensors. My next challenge is to show the two sensors below in percentages.
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO16
      mode:
        input: true
        pulldown: true
  # Second sensor
  - platform: gpio
    pin:
      number: GPIO5
      inverted: true
      mode: INPUT_PULLUP
captive_portal:
binary_sensor:
  • platform: gpio
    pin:
    number: D1
    mode:
    input: true
    pullup: true
    name: Water Sensor 1
    filters:
    • invert
  • platform: gpio
    pin:
    number: D2
    mode:
    input: true
    pullup: true
    name: Water Sensor 2
    filters:
    • invert
works with xkc-y23a npn
