Since Hassio V0.76 I’m having some issues with KNX XKNX. At times Hassio stops reading / sending values on the Bus. It is only working fine after a reboot.
Log gives the following:
2018-09-03 15:10:22 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-09-03 15:10:26 WARNING (MainThread) [xknx.log] Error: reading rading group address from KNX bus failed: ErrorCode.E_CONNECTION_ID
2018-09-03 15:10:31 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-09-03 15:10:32 WARNING (MainThread) [xknx.log] Error: reading rading group address from KNX bus failed: ErrorCode.E_CONNECTION_ID
2018-09-03 15:10:32 WARNING (MainThread) [xknx.log] Heartbeat failed - reconnecting
2018-09-03 15:10:32 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/local/lib/python3.6/site-packages/xknx/io/tunnel.py”, line 183, in do_heartbeat
await self.do_heartbeat_impl()
File “/usr/local/lib/python3.6/site-packages/xknx/io/tunnel.py”, line 191, in do_heartbeat_impl
await self.do_heartbeat_failed()
File “/usr/local/lib/python3.6/site-packages/xknx/io/tunnel.py”, line 202, in do_heartbeat_failed
await self.reconnect()
File “/usr/local/lib/python3.6/site-packages/xknx/io/tunnel.py”, line 167, in reconnect
await self.start()
File “/usr/local/lib/python3.6/site-packages/xknx/io/tunnel.py”, line 75, in start
await self.connect()
File “/usr/local/lib/python3.6/site-packages/xknx/io/tunnel.py”, line 86, in connect
await connect.start()
File “/usr/local/lib/python3.6/site-packages/xknx/io/request_response.py”, line 35, in start
await self.send_request()
File “/usr/local/lib/python3.6/site-packages/xknx/io/request_response.py”, line 43, in send_request
knxipframe = self.create_knxipframe()
File “/usr/local/lib/python3.6/site-packages/xknx/io/connect.py”, line 21, in create_knxipframe
(local_addr, local_port) = self.udp_client.getsockname()
File “/usr/local/lib/python3.6/site-packages/xknx/io/udp_client.py”, line 182, in getsockname
sock = self.transport.get_extra_info(“sockname”)
AttributeError: ‘NoneType’ object has no attribute ‘get_extra_info’
2018-09-03 15:10:35 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-09-03 15:10:40 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-09-03 15:10:43 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-09-03 15:10:47 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-09-03 15:10:57 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
Hassio is installed on Rasberry Pi and I run V0.77.2
Thank you for Hassio and the work you’re doing. It is awesome.
Regards,
M
