OlliVa
(olli va)
December 3, 2020, 12:34pm
1
Does anyone know, which integration causes this message?
Logger: custom_components.hacs.factory
Source: custom_components/hacs/operational/factory.py:27
Integration: HACS (documentation , issues )
First occurred: 2. Dezember 2020, 10:20:23 (3 occurrences)
Last logged: 13:00:23
xMrVizzy/button-toolbar - GitHub returned 404 for https://api.github.com/repos/xMrVizzy/button-toolbar
COX
December 4, 2020, 5:53am
2
This repository is no longer in GitHub and I am getting the fans errors. I don’t know how to remove it from HACS so it does not look for it anymore.
Maybe an HACS update is needed.
Valiceemo
(Richard)
December 4, 2020, 2:56pm
3
Also getting the error, interesting to see which component it is
pepe59
(Pepe59)
December 4, 2020, 8:27pm
5
The same thing happened to me the previous 2 days. Today the error didn’t show up.
same error here - 2020-12-04 17:02:29 ERROR (MainThread) [custom_components.hacs.repository.plugin.xMrVizzy.button-toolbar] GitHub returned 404 for https://api.github.com/repos/xMrVizzy/button-toolbar
Same error here:
2020-12-04 22:26:05 ERROR (MainThread) [custom_components.hacs.repository.plugin.xMrVizzy.button-toolbar] GitHub returned 404 for https://api.github.com/repos/xMrVizzy/button-toolbar
pepe59
(Pepe59)
December 5, 2020, 9:40am
8
Today this error reappeared and I can’t find out what it is. Everything works fine.
MarH
(Martin)
December 5, 2020, 12:33pm
9
I’ve found a fork of the original … you can add this as a custom repository in HACS
pepe59
(Pepe59)
December 5, 2020, 1:34pm
10
Okay, but I don’t use this component and I’ve never used it so why does it appear as a bug?
pepe59
(Pepe59)
December 17, 2020, 10:22pm
12
I have updated everything to the latest versions of HassOS, HA, Supervisor, HACS and this bug no longer occurs
shoguevara
(shoguevara)
December 20, 2020, 4:44pm
13
I’ve added a custom repo MarH mentioned. Restarted HA a couple of times, then deleted both “Button-toolbar” custom repos. It seems top be gone now. At last!
Finally i’ve found a solution to del repo definitely.
Go into .storage directory.
Open hacs.repositories and take note to the number of repo to be delete (our case button-toolbar).
Delete all code from “xxxxxxx” (where x is the number of repo) and “},”.
Go to .storage/hacs and delete xxxxxxxxxxx.hacs file (where x is the number of repo)
Restart Hassio and the issue are gone.
Regards,
Alessandro
