> [14:08:28] INFO: Successfully send discovery information to Home Assistant.
> 14:08:29.078 DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
> 14:08:29.084 DRIVER version 6.2.0
> 14:08:29.085 DRIVER
> 14:08:31.163 CNTRLR beginning interview...
> 14:08:31.163 CNTRLR querying version info...
> 14:08:32.216 CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
> n 100 ms.
> 14:08:33.319 CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
> n 1100 ms.
> 14:08:35.425 DRIVER Failed to initialize the driver: Timeout while waiting for an ACK from the con
> troller
> Error in driver ZWaveError: Failed to initialize the driver: Timeout while waiting for an ACK from the controller
> at Immediate.<anonymous> (/usr/lib/node_modules/@zwave-js/server/node_modules/zwave-js/src/lib/driver/Driver.ts:721:6) {
> code: 5,
> context: undefined,
> transactionSource: undefined
Last night I got my JS working with no problems was able to see and control the objects. Though I would go through to day and rename the entities.
I saw there was an update available and applied it.
Now I get the above error in the log. Yes I have restarted it, a few times. Yes I removed the old info from the conguration.yaml
Tell me what you want to see, besides winning lottery numbers, and I will get it.
Thanks!
-Larry
