Looking for a bit of guidance here because all the other threads relating to migrations focus on HA installs dissimilar to mine.
Currently I have HA on a Rpi3 running raspbian installed in a venv from these instructions https://www.home-assistant.io/docs/installation/virtualenv/. I’m looking to migrate this installation to a repurposed intel laptop running Ubuntu Server 18.04. I don’t use Docker and don’t intend to - I certainly don’t want Docker for HA because I have too many hardware devices I want it to have direct access too and also I like to tinker with bits in HA.
So my question is this: how can I move my install which currently resides here /srv/homeassistant with config files in /home/homeassistant/.homeassistant to the new laptop? I have read some guides which suggest just installing HA again and copying across config files but what if you’ve tweak in custom components and tweaked things inside the /srv/homeassistant folder (specifically I have changed the odd thing in openzwave) - although I have to admit I haven’t checked if these things survived the update I did to HA.
Anyway thanks in advance for any help/advice!
