anyone using the yale assure 2 lock? I have the YRD-450 with the z-wave module. the zwave is working but I cannot configure an access code unless I am using the yale app and within bluetooth range. anyone know if the Bluetooth integration with HA allows you to set an access code remotely? how did you find the Offline key (32-byte hex string) and the offline key slot (integer between 0 and 255) when configuring the lock in HA via bluetooth integration?
I don’t have this lock. I’ve been researching. does this comment help you? https://community.home-assistant.io/t/smart-locks-compatible-with-home-assistant/590662/5
thanks. Yes, I had seen that but have not given it a try yet (to install the august integration). I will post here if that works in my case.
Thanks, I did not know that was there. I was testing it out, how do you know what the “code slot” is?
Hey, I know it’s been a while, but did you succeed ? I am considering buying this one: Amazon.com: Yale Assure Lock 2 Deadbolt, Black Suede Keypad Code Door Lock with Z-Wave and Back-Up Key for Front or Back Entry Door, YRD410-ZW2-BSP
