For Yale assure lock 2 bluetooth + Raspberry Pi 3B+ bluetooth - I am keep getting random “Failed to connect” and/or “Bluetooth error updating”
Raspberry Pi is right next to the door
I am using August login + Yale access bluetooth integration. When connection works randomly, it works but once it loses connection it takes awhile to be connected again.
There was recent offline key issue update, and I restarted Raspberry Pi with full power down/restart but seems update didn’t do much.
I believe it might be something to do with combinations of wifi channel/zigbee being too close to raspberry pi and etc. or really the update from both of HA/Yale. So far I am not seeing any disconnections.
I have put the Zigbee dongle bit far usb extended from Raspberry Pi, as well as using wired ethernet connection.
