Yale Assure SL with IM1 and bluetooth proxy
I am trying to set up a Yale Assure SL(with the IM1 module) as a HomeKit device with a bluetooth proxy.
It shows up in HA as a discovered device:
But when i hit configure, it eventually times out with:
The debug logs for bleak in HA are:
2024-09-13 12:07:30.057 DEBUG (MainThread) [bleak_retry_connector] Yale Lock (DE:B0:94:3B:97:3E) - DE:B0:94:3B:97:3E: Connection attempt: 1
2024-09-13 12:07:41.033 DEBUG (MainThread) [bleak_retry_connector] Yale Lock (DE:B0:94:3B:97:3E) - DE:B0:94:3B:97:3E: Failed to connect: Error ESP_GATT_CONN_TERMINATE_PEER_USER while connecting: Connection terminated by peer user, device_missing: False, backing off: 0.25 (attempt: 1, last rssi: None)
2024-09-13 12:07:41.284 DEBUG (MainThread) [bleak_retry_connector] Yale Lock (DE:B0:94:3B:97:3E) - DE:B0:94:3B:97:3E: Connection attempt: 2
2024-09-13 12:07:51.960 DEBUG (MainThread) [bleak_retry_connector] Yale Lock (DE:B0:94:3B:97:3E) - DE:B0:94:3B:97:3E: Failed to connect: Error ESP_GATT_CONN_TERMINATE_PEER_USER while connecting: Connection terminated by peer user, device_missing: False, backing off: 0.25 (attempt: 2, last rssi: None)
2024-09-13 12:07:52.211 DEBUG (MainThread) [bleak_retry_connector] Yale Lock (DE:B0:94:3B:97:3E) - DE:B0:94:3B:97:3E: Connection attempt: 3
2024-09-13 12:08:02.499 DEBUG (MainThread) [bleak_retry_connector] Yale Lock (DE:B0:94:3B:97:3E) - DE:B0:94:3B:97:3E: Failed to connect: Error ESP_GATT_CONN_TERMINATE_PEER_USER while connecting: Connection terminated by peer user, device_missing: False, backing off: 0.25 (attempt: 3, last rssi: None)
2024-09-13 12:08:02.751 DEBUG (MainThread) [bleak_retry_connector] Yale Lock (DE:B0:94:3B:97:3E) - DE:B0:94:3B:97:3E: Connection attempt: 4
2024-09-13 12:08:13.038 DEBUG (MainThread) [bleak_retry_connector] Yale Lock (DE:B0:94:3B:97:3E) - DE:B0:94:3B:97:3E: Failed to connect: Error ESP_GATT_CONN_TERMINATE_PEER_USER while connecting: Connection terminated by peer user, device_missing: False, backing off: 0.25 (attempt: 4, last rssi: None)
2024-09-13 12:08:13.289 DEBUG (MainThread) [bleak_retry_connector] Yale Lock (DE:B0:94:3B:97:3E) - DE:B0:94:3B:97:3E: Connection attempt: 5
2024-09-13 12:08:23.511 DEBUG (MainThread) [bleak_retry_connector] Yale Lock (DE:B0:94:3B:97:3E) - DE:B0:94:3B:97:3E: Failed to connect: Error ESP_GATT_CONN_TERMINATE_PEER_USER while connecting: Connection terminated by peer user, device_missing: False, backing off: 0.25 (attempt: 5, last rssi: None)
2024-09-13 12:08:23.762 DEBUG (MainThread) [bleak_retry_connector] Yale Lock (DE:B0:94:3B:97:3E) - DE:B0:94:3B:97:3E: Connection attempt: 6
ESP console logs:
[12:04:42][I][bluetooth_proxy:282]: [0] [DE:B0:94:3B:97:3E] Connecting v3 without cache
[12:04:42][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[12:04:42][I][esp32_ble_client:067]: [0] [DE:B0:94:3B:97:3E] 0x01 Attempting BLE connection
[12:04:43][D][esp32_ble_client:110]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_CONNECT_EVT
[12:04:43][D][esp32_ble_client:110]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_OPEN_EVT
[12:04:43][D][esp32_ble_tracker:270]: Starting scan...
[12:04:53][D][esp32_ble_client:172]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_DISCONNECT_EVT, reason 19
[12:04:54][D][esp32_ble_client:110]: [0] [] ESP_GATTC_CLOSE_EVT
[12:04:54][I][bluetooth_proxy:282]: [0] [DE:B0:94:3B:97:3E] Connecting v3 without cache
[12:04:54][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[12:04:54][I][esp32_ble_client:067]: [0] [DE:B0:94:3B:97:3E] 0x01 Attempting BLE connection
[12:04:54][D][esp32_ble_client:110]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_CONNECT_EVT
[12:04:54][D][esp32_ble_client:110]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_OPEN_EVT
[12:04:55][D][esp32_ble_tracker:270]: Starting scan...
[12:05:04][D][esp32_ble_client:172]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_DISCONNECT_EVT, reason 19
[12:05:04][D][esp32_ble_client:110]: [0] [] ESP_GATTC_CLOSE_EVT
[12:05:05][I][bluetooth_proxy:282]: [0] [DE:B0:94:3B:97:3E] Connecting v3 without cache
[12:05:05][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[12:05:05][I][esp32_ble_client:067]: [0] [DE:B0:94:3B:97:3E] 0x01 Attempting BLE connection
[12:05:09][D][esp32_ble_client:110]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_CONNECT_EVT
[12:05:09][D][esp32_ble_client:110]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_OPEN_EVT
[12:05:09][D][esp32_ble_tracker:270]: Starting scan...
[12:05:19][D][esp32_ble_client:172]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_DISCONNECT_EVT, reason 19
[12:05:19][D][esp32_ble_client:110]: [0] [] ESP_GATTC_CLOSE_EVT
[12:05:19][I][bluetooth_proxy:282]: [0] [DE:B0:94:3B:97:3E] Connecting v3 without cache
[12:05:19][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[12:05:19][I][esp32_ble_client:067]: [0] [DE:B0:94:3B:97:3E] 0x01 Attempting BLE connection
[12:05:23][D][esp32_ble_client:110]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_CONNECT_EVT
[12:05:23][D][esp32_ble_client:110]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_OPEN_EVT
[12:05:23][D][esp32_ble_tracker:270]: Starting scan...
[12:05:33][D][esp32_ble_client:172]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_DISCONNECT_EVT, reason 19
[12:05:33][D][esp32_ble_client:110]: [0] [] ESP_GATTC_CLOSE_EVT
[12:05:33][I][bluetooth_proxy:282]: [0] [DE:B0:94:3B:97:3E] Connecting v3 without cache
[12:05:33][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[12:05:33][I][esp32_ble_client:067]: [0] [DE:B0:94:3B:97:3E] 0x01 Attempting BLE connection
[12:05:37][D][esp32_ble_client:110]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_CONNECT_EVT
[12:05:37][D][esp32_ble_client:110]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_OPEN_EVT
[12:05:37][D][esp32_ble_tracker:270]: Starting scan...
[12:05:47][D][esp32_ble_client:172]: [0] [DE:B0:94:3B:97:3E] ESP_GATTC_DISCONNECT_EVT, reason 19
[12:05:47][D][esp32_ble_client:110]: [0] [] ESP_GATTC_CLOSE_EVT
I have removed the lock from my Apple Home and the Yale app. I have also tried factory resetting it and setting it up from scratch.
No firmware updates are available for the lock in the Yale app.
Just to rule out a firmware/homekit issue, I have successfully added the device to my Apple Home directly and it works flawlessly.
Homeassistant is 2024.9.0 (supevisor mode)
ESPHome is 2024.8.3
Any ideas?
My bluetooth proxy config is pretty plain:
esp32_ble_tracker:
  scan_parameters:
    interval: 320ms
    window: 30ms
    active: false
bluetooth_proxy:
  active: true
I have tried with both active and passive scanning, and bumping up the scan parameters to 1100ms
I noticed that the last rssi in the bleak logs is None, which I’m not sure about. The bluetooth proxy is about 2m away from the lock with clear LoS so I don’t think it’s a connectivity issue
