I would like to request for the new Yale home app to support fetching the offline keys.
After the split from August it is no longer possible to login in August app using Yale home account. And the august app provided the offline keys.
I suspect this code to fetch and provide the offline keys was not copied to the new Yale home app in the split.
So right now there is no way for Yale home users to get the Yale Bluetooth integration working
Related to fault report: Yale Access Bluetooth - No Longer Functioning Since Moving To Yale Home · Issue #126117 · home-assistant/core · GitHub
WallyR
(Wally)
September 25, 2024, 5:27pm
2
Is this related to the Home Assistant integration?
Home Assistant does not make the August and Yale Home Apps, so you might have to contact the vendors for changes in that.
Jay_Jay
September 26, 2024, 11:34am
3
The offline keys were fetched by the August integration. That integration was removed and replaced by Yale. It was supposed to do the same thing but doesn’t.
It is a core component owned by user bdraco
Apparently he is in contact with Yale to get support for it in the new API: Yale Access Bluetooth - No Longer Functioning Since Moving To Yale Home · Issue #126117 · home-assistant/core · GitHub
WallyR
(Wally)
September 30, 2024, 7:31pm
5
It was the use of the term app that made me post the comment.
If it is regarding the integration, then no problem.
Hedda
(Hedda)
October 1, 2024, 11:28am
6
I was just replying to WallyR. You can find the bug report in the first post.
