Yale L1 Connexis Lock issues
Hi All,
I am having a nightmare getting my L1 lock working within Home Assistant, and am now out of ideas, or steps to follow to try and troubleshoot.
My config is a respberry pi, with the ZWave RAZBERRY board, and using ZWave.JS. I have successfully paired the ZWave dongle and the lock, and can see the entities and devices in HA (showing as Node3). It successfully replies to a ping, and I can see the ‘lock’ and unlock buttons. However, the ‘current status’ is showing as unknown.
I have added and removed the device, and still see the same issue.
When I check ht elogs, I see:
2022-07-17T21:58:39.781Z DRIVER » [Node 003] [REQ] [SendData]
                                  │ transmit options: 0x25
                                  │ callback id:      204
                                  └─[DoorLockCCOperationSet]
                                      target mode: Unsecured
2022-07-17T21:58:39.788Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-07-17T21:58:39.812Z DRIVER « [REQ] [SendData]
                                    callback id:            204
                                    transmit status:        OK, took 30 ms
                                    routing attempts:       1
                                    protocol & route speed: Z-Wave, 40 kbit/s
                                    ACK RSSI:               -69 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
2022-07-17T21:58:39.910Z DRIVER » [Node 003] [REQ] [SendData]
                                  │ callback id:      205
2022-07-17T21:58:39.917Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-07-17T21:58:39.947Z DRIVER « [REQ] [SendData]
                                    callback id:            205
                                    routing attempts:       1
                                    ACK RSSI:               -68 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
2022-07-17T21:58:40.097Z DRIVER » [Node 003] [REQ] [SendData]
                                  │ callback id:      206
2022-07-17T21:58:40.104Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-07-17T21:58:40.134Z DRIVER « [REQ] [SendData]
                                    callback id:            206
                                    routing attempts:       1
                                    ACK RSSI:               -69 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
2022-07-17T21:58:45.162Z DRIVER » [Node 003] [REQ] [SendData]
                                  │ callback id:      207
                                  └─[DoorLockCCOperationGet]
2022-07-17T21:58:45.170Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-07-17T21:58:46.437Z DRIVER « [REQ] [SendData]
                                    callback id:            207
                                    transmit status:        OK, took 1260 ms
                                    routing attempts:       4
                                    ACK RSSI:               -69 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
                                    beam:                   1000 ms
2022-07-17T21:58:48.738Z CNTRLR   [Node 003] Timed out while waiting for a response from the node (ZW0201)
2022-07-17T22:04:04.680Z DRIVER » [Node 003] [REQ] [SendData]
                                  │ callback id:      208
2022-07-17T22:04:04.689Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-07-17T22:04:05.901Z DRIVER « [REQ] [SendData]
                                    callback id:            208
                                    transmit status:        OK, took 1220 ms
                                    routing attempts:       4
                                    ACK RSSI:               -68 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
                                    beam:                   1000 ms
2022-07-17T22:04:05.927Z DRIVER » [Node 003] [REQ] [SendData]
                                  │ callback id:      209
2022-07-17T22:04:05.935Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-07-17T22:04:05.960Z DRIVER « [REQ] [SendData]
                                    callback id:            209
                                    routing attempts:       1
                                    ACK RSSI:               -69 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
2022-07-17T22:04:10.985Z DRIVER » [Node 003] [REQ] [SendData]
                                  │ callback id:      210
2022-07-17T22:04:10.993Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-07-17T22:04:12.274Z DRIVER « [REQ] [SendData]
                                    callback id:            210
                                    transmit status:        OK, took 1280 ms
                                    routing attempts:       4
                                    ACK RSSI:               -69 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
                                    beam:                   1000 ms
2022-07-17T22:04:14.590Z CNTRLR   [Node 003] Timed out while waiting for a response from the node (ZW0201)
Log Level changed to: Debug
2022-07-17T22:04:42.449Z SERIAL » 0x010a0013030362010025d373                                          (12 bytes)
2022-07-17T22:04:42.451Z DRIVER » [Node 003] [REQ] [SendData]
                                  │ callback id:      211
2022-07-17T22:04:42.457Z SERIAL « [ACK]        (0x06)
2022-07-17T22:04:42.461Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2022-07-17T22:04:42.463Z SERIAL » [ACK]        (0x06)
2022-07-17T22:04:42.466Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-07-17T22:04:43.679Z SERIAL « 0x01180013d300007b00bc7f7f7f7f0101030000000042040000a5              (26 bytes)
2022-07-17T22:04:43.684Z SERIAL » [ACK]        (0x06)
2022-07-17T22:04:43.690Z DRIVER « [REQ] [SendData]
                                    callback id:            211
                                    transmit status:        OK, took 1230 ms
                                    routing attempts:       4
                                    ACK RSSI:               -68 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
                                    beam:                   1000 ms
2022-07-17T22:04:48.718Z SERIAL » 0x010900130302620225d475                                            (11 bytes)
2022-07-17T22:04:48.720Z DRIVER » [Node 003] [REQ] [SendData]
                                  │ callback id:      212
2022-07-17T22:04:48.723Z SERIAL « [ACK]        (0x06)
2022-07-17T22:04:48.729Z SERIAL « 0x0104011301e8                                                       (6 bytes)
2022-07-17T22:04:48.731Z SERIAL » [ACK]        (0x06)
2022-07-17T22:04:48.734Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-07-17T22:04:50.027Z SERIAL « 0x01180013d400008200bb7f7f7f7f01010300000000420400005c              (26 bytes)
2022-07-17T22:04:50.032Z SERIAL » [ACK]        (0x06)
2022-07-17T22:04:50.037Z DRIVER « [REQ] [SendData]
                                    callback id:            212
                                    transmit status:        OK, took 1300 ms
                                    routing attempts:       4
                                    ACK RSSI:               -69 dBm
                                    ACK channel no.:        1
                                    TX channel no.:         1
                                    beam:                   1000 ms
2022-07-17T22:04:52.379Z CNTRLR   [Node 003] Timed out while waiting for a response from the node (ZW0201)
Subscribed to Z-Wave JS Log Messages…
I’ve moved the controller closer, and done the heal and re-interview process, which is successful. Still no luck.
What am I missing?
