Yale Smart Living: Can't set up: Authentication failed. Check credentials
So, I’ve tried for quite a few days now to set up the Yale Smart Living integration without success. Any hints?
Only result I get is “Authentication failed. Check credentials” when trying to add the integration using a username/password that I indeed CAN log in using in both the app and some website. I have left Name default “Yale Smart Alarm” and Area id default “1”.
Any hints? I have tried using phone number and mail as username, multiple times. Tried “0046…”, “+46…”, “46…” as country code prefixes.
I saw this issue a month or so ag, but I suppose the Yale servers are up now? Yale Smart Alarm Authentication failed. · Issue #59829 · home-assistant/core · GitHub
Any help would be appreciated.
/Victor
I’m having the same issue did you ever get it resolved?
I am also having the same issue. Have you had any luck in resolving it?
Same issue here. How is it that they can have a field on the setup for ‘Area ID’ and ZERO documentation regarding what the hell that is for?
Has someone unveiled that secret?
I’m also struggling on the Area-ID
