Yale Smart Lock to replace UK nightlatch
I’m looking to buy this lock to replace the existing nightlatch on a house I’m moving to shortly
If I get it with the included zWave module will it just get detected by HA or do I need an additional hub/gateway before that happens? I don’t have a Smartthings hub although I do have the Smartthings app on my phone and it has detected various devices including a Samsung TV, my Ring cameras and a couple of Tapo smart switches which it can control fine without me owning a Smartthings hub (mind you, this all worked before HA too).
I have an instance of HA running on an RPI 4 and the only hub I have which I think is zWave is the hub that came with my Ring Alarm system and HA sees all the Ring devices fine (contact/motion sensors etc).
I
Hi. Did you manage to get this working. I’m hoping to do the same thing. Although I believe the lock’s z-wave module needs to be added direct to the Ring hub to get full control. Keen to know if you got it going…
FYI I have exactly the same lock.
Also Keen on any advice on this. Mine is probably 5 years old and working on smartthings. Obviously retiring last of my ST so want to add to HA just keen to know if it’ll work.
I am looking at getting one of these locks. Does anyone know if they work with the existing HA integration? The model is not listed on the page.
Yale Access Bluetooth - Home Assistant (home-assistant.io)
Yes, this works perfectly with HA. I am using it today.
Hi Simon, I’m looking at getting this lock and a Z-wave module - Could I ask what integration you used in HA for it? Any other tips? I don’t own any Z-wave devices so will need to purchase a stick - which one do\did you use?
