Hello everyone there is a way to integrate this YALE Y05 / 101200 / SI - Smart Lock Linus lock into Home Assistant
solved with this
integration with August, if it doesn’t work:
- Install the August app
- recover password
- put same password as Yale app
- Log in again
And it works as expected?
You can lock and unlock the door from HA?
See the state?
Unfortunately you can only lock, check the status and the battery
Not unlock??!
Unfortunately no it does not unlock. sin
Sigh!
I was hoping this was a good lock.
It seems impossible to find a good lock.
I want full control from HA and a key override.
I found the key to unlock. It works
Please tell us more
Can I use this lock locally, without august/yale login? Is there a solution already?
Is there already a solution here how the unlock and open in Home Assistant works?
