I have a couple of Yale YRD226 door locks with Zigbee modules.
These have been working well and were previously paired to an Icontrol home automation system via Zigbee. I have now switched the setup over to HA and I have successfully paired and used the locks.
On the Icontrol system I would get notified if there was a jammed locked as well as how the lock was opened (for example manually at the lock or by user code). So I know that the Yale lock has the capabilities to send these status codes via Zigbee.
However when I look at my devices in HA I can only see the lock and the battery sensor and all the research I have done has only turned up Z-Wave examples. Does anyone have more info on how to monitor these extended status codes via Zigbee?
