Yale YRD256 Lock - Battery 100% with a "Replace Battery Soon" Notification
I have two Yale Locks with “Replace Battery” notifications even though the batteries are at 100%. One of the locks is working properly, and it does not show a Replace Battery notification. Here’s a screenshot of the device with the incorrect message:
And the screenshot from zwavejs2mqtt:
Does anyone know how I can reset the message that the battery needs to be replaced soon? Thanks!
Did you ever figure this out?
Had forgotten about this, looks like the issue is still happening in latest HA + Zwave JS - was thinking maybe updated lock firmware might help but can’t find any online.
Interesting, so did you just disable the replace battery soon sensor?
I excluded from my battery check automation, wasn’t able to get it to work properly.
I also have this issue and cannot find a solution other than disabling that entity in my battery alert automation.
Press the “Idle Battery maintenance status” button entity, accessible via the device page or entity list.
I think that did it, thank you!
