I think this error may be because a sensor I’ve set up below cannot instantly read the battery level when HA is restarted as Z-wave is not ready for a few seconds/minutes after restart? Any way to fix that and remove the warning?
- alias: 'Notify front door battery low'
platform: numeric_state
entity_id: zwave.frontdoor_deadbolt
# Optional
value_template: '{{ states.zwave.frontdoor_deadbolt.attributes.battery_level }}'
below: 75
# If given, will trigger when condition has been for X time.
for:
hours: 1
- service: notify.hass_synochat
message: "Deatbolt battery is below 75%"
2019-02-03 18:29:21 WARNING (MainThread) [homeassistant.helpers.condition] Value cannot be processed as a number: <state zwave.frontdoor_deadbolt=unknown; node_id=18, node_name=Assa Abloy Yale Key Free Touchscreen Deadbolt (YRD240), manufacturer_name=Assa Abloy, product_name=Yale Key Free Touchscreen Deadbolt (YRD240), friendly_name=Deadbolt @ 2019-02-03T18:29:21.207079+13:00> (Offending entity: )
2019-02-03 18:29:21 WARNING (MainThread) [homeassistant.helpers.condition] Value cannot be processed as a number: <state zwave.frontdoor_deadbolt=initializing; node_id=18, node_name=Assa
Abloy Yale Key Free Touchscreen Deadbolt (YRD240), manufacturer_name=Assa Abloy, product_name=Yale Key Free Touchscreen Deadbolt (YRD240), query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=False, capabilities={'routing', 'beaming', 'frequent'}, sentCnt=0, sentFailed=0, retries=0, receivedCnt=0, receivedDups=0, receivedUnsolicited=0, sentTS=2019-02-03 18:29:09:368 , receivedTS=2019-02-03 18:29:09:368 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, friendly_name=Deadbolt @ 2019-02-03T18:29:21.752350+13:00> (Offending entity: )
