Thank you for the advice I have tried that and also removing the batteries for 10 mins
It happened a few weeks ago, the next day I rang yale And while on the phone it started working again.
The person I spoke with hadn’t heard of the issue before and asked me video if it happens again, I’ve now done that but with it being the Easter break they are closed until Tuesday (I’m in the UK).
2yrs last Oct
Now there is one thing it first happened when I switched over to zwave js and used HA to unlock the door. Knowing I couldn’t ring yale until the morning I switched back to the old zwave in HA (as mentioned it was still doing it, until the moment I got in contact with yale ) .
That said, I moved the entire system to a new rpi and SSD and this time installed Zwave JS straight away, that was 1 week ago. This morning I hit the unlock button in HA (which I’ve done numerous times this week) and it started happening again.
lol I love coincidences.
I’m with ZwaveJS at the mo. Not tried to go back, because I only have this lock on it.
I know the battery level doesn’t report on time, and for now the alarmtype doesn’t report at all, but It’s not mission critical so I can live with it until it gets fixed (though I really should see if this has been reported and report it myself if not)…
EDIT: our AlarmType issue may be related to the fact that RElease 3.0.0 (zwavejs V7) is incompatible with HA versions before 2021.4.x:
Really! Me not so much right now lol
I always work on a process of a limitation, and thats the one thing that connects to the two events.
Again I can’t see how it could be, but the back of my head says… But could it.
This yale lock is my only z wave device too.
Currently I’ve accepted the facts: it’s broken and I’m out of warrently and I’ve been unlucky to have a fault no one else on the entire Internet has reported/mentioned (until now)
Slightly off HA topic, but has anyone managed to get 3rd party RFID tags to work directly with the lock?
I have a RFID tag on the outside wall next to the door that is linked to an iOS shortcut that when I tap my iPhone it uses HA to open the door, but It would be great to be able to pair a 3rd party fob to the door.
This hasn’t been reported to my knowledge if it needs the alarm type/value mapping. It’s an easy add if it needs it but no one has asked for it to be mapped. I believe they rescinded that incompatibility note after the email went out though I could be wrong.
This has started with mine too, no updates on them but everything else works.
Did you try and exclude and re-include the lock ? Don’t know if its worth trying that
Hi guys,
I’ve noticed the the new z wave integration only updates the alarm level when it detects a different key.
This is a real pain as I have an automation that turns my alarm off if it detects one of our keys, so I only use one key the automation doesn’t trigger.
Same here with my Yale Conexis L1 lock - stuck on ‘alarmType 144’.
Very annoying, it was good to know when the lock gets jammed by someone not lifting handle properly.
I have tried downgrading to Core-2021.3.4 and still no joy.
I actually downgraded because of the sluggish UI while trying to amend Automations in version 2021.4…onwards, not usable with large automations on the RPI4.
Hi all,
I noticed the z-wave JS has been updated and has an update to this lock and its mapping.
The issue I saw that made me drop back to the old zwave config was it didn’t capture who unlocked the door on every occasion (based on the fob). It would only update when a different fob was used.
Can someone on the js z wave confirm if this is still the case.
I can’t really see any improvements to be honest.
Not sure what I’m looking for here though, but the AlarmType and AlarmLevel entitites aren’t giving me the info I’m after.
At the moment I’m getting by with a template sensor that is a combination of the lock status and the AlarmType and AlarmLevel entitites :
I have 1 sensor that extracts information from the AlarmType and AlarmLevel entitites:
sensors:
yale_alarmtype_status:
value_template: >
{% if states("sensor.yale_conexis_l1_alarmtype") == "144" and states("sensor.yale_conexis_l1_alarmlevel") == "2" %}Unlocked by RFID tag (Div)
{% elif states("sensor.yale_conexis_l1_alarmtype") == "144" and states("sensor.yale_conexis_l1_alarmlevel") == "3" %}Unlocked by RFID tag (Lolo)
{% elif states("sensor.yale_conexis_l1_alarmtype") == "16" %}Unlocked by Yale App
{% endif %}
then I have a temnplate trigger sensor to combine all sensors into a single one:
The above is a trigger template sensor, so it takes the state from the sensor that changed last.
It kinda works for me for now, though it’s a bit scrappy.
I’m also having to use automations to force pull sensor data like the battery else it does not update automatically.
I can’t be *rsed to go back so I’ve done this for now.
