I recently purchased a Zigbee lock - a Yale Assy Abloy Deadbolt (its actually Lockwood Brand - but seems to be a Yale in HA)
I also got a Conbee II zigbee stick so I’m new to how it all works. however I have successfully written some automation to lock and unlock the door however the status of the lock doesn’t update if I lock the lock manually - is there a polling interval or service i can call to update it ? When I go into Deconz and select the lock, I can “read” some attributes and the status updates in HA - just don’t know how to do this without going into deconz.
Also what are most people doing - using deconz or zigbee2mqtt , just curious on what others are doing?
I configured a Yale YRD226 with a Zigbee module this weekend using ZHA (Nortek Zigbee/ZWave USB key), and it was super straightforward: go into HA and enable joining for new devices, go the Yale lock menu and do a “join network”, and… that’s about it.
It took a couple of attempts for the joining to actually succeed, which is no unusual for Zigbee devices on a large network with multiple routers, but once it worked, I got a “Lock” button and a battery status button, it couldn’t be easier… The integration seems to be stable so far.
It takes a couple of seconds, maybe 5 to 10 worst case? Not instant at all, but it does update eventually.
I ended up having to write a couple of scripts to add an “unlocking” state to the lock/unlock button so that users would not press it multiple times waiting for the lock to react.
Hi @elafargue I have the same issue with my yrd256, delay in lock and unlcok status update in HA through ZHA. Would you mind sharing the script you made to work around it.
