Yamaha_musiccast
Hi!
Does somebody know how to setup more then one device under yamaha_musiccast?
I have one YSP-2700 and one wx-030 but I only can see YSP-2700…
Of course I’ve different IP´s on the devices
My config file looks like:
Media Players
media_player:
  • platform: yamaha_musiccast
    host: xxx.xxx.xxx.xxx
Thanx in advance
I habe the same problem, having two wx-10. The log files gives the warning saying that for the second wx-10 the port is already registered.
I found a solution:
Just define a different port for each music cast device:
port: 5005
port: 5004
It worked for me :smile:
Thanks a lot! Will try that. You just changed in config, nothing on the Yamaha devices?
yes exactly…
i looked up in the component py-file and as far as i understood it tries du find duplicates. Unfortunately two devices on the same port will be interpreted as a duplicate. Looks like a bug for me.
The port entry does not effect the communication with the musiccast device. Tried it today and worked fine.
Thanks s lot!
Hi Noobie - are you able to google TTS to the muciccast devices?
Sorry haven’t tried it…
OK, thanks - I have been trying to get Google TTS to Yamaha MusicCast to work but no luck - will post back if I ever find a solution, fingers crossed.
Great, thanks
wohoooo worked as well for me :slight_smile:
someone a idea how to use google tts now??! Or some local mp3 files? :slight_smile:
I would like to know the TTS as well, also is there a way to rename it? With the older non musiccast amps you could add a name…
Hi. Have you been able to configure your yamaha device to play a specific mp3 file from a specified media server? I’ve gone through the api document, but no sign of this ability.
