Hi there!
a few weeks ago, Home Assistant started loosing the connection to my Yamaha RX-A870. I think, it started with the HA update to 0.115, but i am not quite sure.
Anyway, after a restart of Home Assistant, the receiver, wich is connected via the Yamaha integration, everything is fine, but a few minutes later HA doesn’t recognize the entity anymore.
In the logs, the following error is shown:
Logger: homeassistant.helpers.entity
Source: components/yamaha/media_player.py:224
First occurred: 3. November 2020, 20:45:51 (1 occurrences)
Last logged: 3. November 2020, 20:45:51
Update for media_player.yamaha_rx_a870_wohnzimmer fails
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 670, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 426, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 421, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.8/http/client.py", line 1347, in getresponse
response.begin()
File "/usr/local/lib/python3.8/http/client.py", line 307, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.8/http/client.py", line 276, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 726, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 410, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.8/site-packages/urllib3/packages/six.py", line 734, in reraise
raise value.with_traceback(tb)
response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 278, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 474, in async_device_update
raise exc
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/yamaha/media_player.py", line 224, in update
self._sound_mode = self.receiver.surround_program
File "/usr/local/lib/python3.8/site-packages/rxv/rxv.py", line 311, in surround_program
response = self._request('GET', request_text)
File "/usr/local/lib/python3.8/site-packages/rxv/rxv.py", line 148, in _request
res = self._session.post(
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 578, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 530, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 643, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
Can someone figure out, what’s the issue?
