Yaml anchors: what is wrong?
Started learning yaml anchors.
Here is a code which works:
type: vertical-stack
cards:
  - type: entities
    entities: &ref_0
      - binary_sensor.updater
  - type: entities
    entities: *ref_0
But this code causes an error:
cards:
  - type: entities
    entities: &ref_0
  - type: entities
    entities: *ref_0
  - type: entities
    entities:
      - <<: *ref_0
      - sun.sun
What am I doing wrong?
cards:
  - type: entities
    entities: &ref_0
  - type: entities
    <<: *ref_0
EDIT: try it out, I might have it wrong. It’s been a while and I’m going off memory. If that doesn’t work then
  - type: entities
    entities: *ref_0
should work.
No, does not work.
It works of course, but I wanted to merge with new entities: old list + new items
You can’t merge lists, only dicts
Oh, very bad…
Thanks a lot for a quick reply!
All this trouble that you’re going through… you should just use lovelace_gen and be done with it.
Started googling about it, thank you!
I use lovelace gen to create my entire interface. No reused code.
Roughly 4000 lines of code that generates up to 300K lovelace lines.
Let me explain you my original need:
  1. There is a decluttering template TEMPLATE_1 with some card, let it be “Entities card” for example.
  2. The card contains a list of entities - let it be ONE entity:
entities:
  - entity: sensor.XXXXXXXX
  1. Now I want to create one more template TEMPLATE_2 - which contains TWO entities:
entities:
  - entity: sensor.YYYYYYYY
  1. It is what I wanted to do:
template_1:
  card:
    type: entities
    entities: &entities_list
      - entity: XXXX
template_2:
  card:
    type: entities
    entities:
      - <<: *entities_list
      - entity: YYYY
And now I realized that it is not possible…
You can do this with lovelace_gen and Jinja
BTW - please, look at this:
cards:
  - type: entities
    entities: &ref_0
      - entity: binary_sensor.updater
  - type: entities
    entities: *ref_0
  - type: entities
    entities:
      - <<: *ref_0
      - sun.sun
It works:
I just added "entity: " word.
this works because it’s a dictionary and the <<: is merging the dictionary into the single listed item. It wouldn’t work if you were to add more listed items into ref_0
Yes, there is something not working here:
added one more entity to the 1st list:
cards:
  - type: entities
    entities: &ref_0
  - type: entities
    entities: *ref_0
  - type: entities
    entities:
      - <<: *ref_0
      - entity: sun.sun
Yah, I’m telling you… there’s no way to merge lists with anchors. Only dictionaries.
list:
mystuff:
- item1
- item2
dictionary:
mystuff:
  item1: a
  item2: b
  item3: c
list of dictionaries
mystuff:
- item1: a
  item2: b
  item3: c
- item1: a
  item2: b
  item3: c
You can only merge with dictionary. Not list or list of dictionaries.
So far I am not getting…
  1. This works:
    list of dicts (2 dicts in the list) copied into another list of dicts:
cards:
  - type: entities
    entities: &ref_0
  - type: entities
    entities: *ref_0
  1. This works:
    list of dicts (1 dict in the list) merged with another list of dicts:
cards:
  - type: entities
    entities: &ref_0
  - type: entities
    entities:
      - <<: *ref_0
      - entity: sun.sun
  1. This does not work:
    list of dicts (2 dicts in the list) merged with another list of dicts - and only the 1st dict is merged:
cards:
  - type: entities
    entities: &ref_0
  - type: entities
    entities:
      - <<: *ref_0
      - entity: sun.sun
Yaml naturally takes a single item list and treats it like the list doesn’t exist. So you’re actually just dealing with a single dictionary when you create &ref_0
You should check out the yaml anchor rules. There’s plenty of them.
I thought that when this dict:
- entity: aaa
is merged with this dict:
- entity: ccc
it must be:
- entity: aaa
  entity: ccc
and must cause an error, but instead it creates this:
- entity: aaa
- entity: ccc
ad it works…
No, because you have the list indicators…
