Sometimes, you have a bunch of repeated YAML code, more than often template code, that is tedious to maintain. Here is what I have put in place to generate this repeated code.
Concepts
- The idea here is to use GO text templates, a quite common tool to generate text, and more specifically the gomplate project, which provides a CLI tool around GO templates.
- Each “project” is comprised of a JSON file that contains data and a template file which is the skeleton of what will be generated
- I’m using a HA Container installation, so I am re-generating the actual HA YAML “code” at each restart through my docker compose file.
- The generated YAML files is included trough the
include_dir_merge_list <the_dir>
syntax; typically, inthe_dir
, I have both manually crafted and generated YAML.
Example
This is a very specific use-case of mine: After my non-HA backups, I publish to a MQTT topic the result of the backup. I want to have this as sensors in HA, but I have more than a dozen different backups, and don’t want to maintain this manually.
gomplate
In a specific /config/gomplate
directory, I have 2 files:
- The “data”:
mqtt_backup_entities.json
(shortened for readability)
"src": "cloud",
"dst": "app",
"dst_path": "/var/data/backups/borg/cloud",
"bucket": "cloud",
"typ": "daily",
"prf": "linx"
"src": "cloud",
"dst": "app",
"bucket": "cloud",
"typ": "daily",
"prf": "cloud2-data"
"src": "cloud",
"dst": "app",
"bucket": "cloud",
"typ": "daily",
"prf": "cloud2-docker_files"
"src": "nas",
"dst": "nas",
"dst_path": "/srv/dev-disk-by-uuid-c8febff8-2b75-4755-88ed-7d3c12176008/local_backup/omvbackup/",
"bucket": "nas-local",
"typ": "daily",
"prf": "omv-backup"
- The go template:
mqtt_backup_entities.tmpl
## gomplate template
## install:
## go install github.com/hairyhenderson/gomplate/v4/cmd/gomplate@latest
## docker:
## docker run -v .:/config hairyhenderson/gomplate:stable -d 'data=file:///config/gomplate/mqtt_backup_entities.json' -f /config/gomplate/mqtt_backup_entities.tmpl -o /config/platforms/mqtt/gmp_backups.yaml
## run:
## gomplate -d 'data=mqtt_backup_entitites.json' -f mqtt_backup_entitites.tmpl -o platforms/mqtt/mqtt_backups.yaml
{{- range $b := (ds "data") }}
- name: "Backup {{ $b.typ }} {{ $b.src }} {{ $b.prf }}"
unique_id: "backup_{{ $b.src }}_{{ $b.prf | strings.ToLower | strings.ReplaceAll "-" "_" }}"
state_topic: "backups/{{ $b.src }}/{{ $b.typ }}/{{ $b.prf }}"
value_template: '{{ "{{" }} value_json["datetime"] {{ "}}" }}'
device_class: timestamp
json_attributes_topic: backups/{{ $b.src }}/{{ $b.typ }}/{{ $b.prf }}
json_attributes_template: >
"type": "{{ $b.typ }}",
"src": "{{ $b.src }}",
"dst": "{{ $b.dst }}",
"dst_path": "{{ $b.dst_path }}",
"bucket": "{{ $b.bucket }}",
"prefix": "{{ $b.prf }}",
"status": "{{ "{{" }} value_json['status'] {{ "}}" }}"
{{- end }}
docker compose
version: '2.1'
services:
gomplate_mqtt_backups:
image: hairyhenderson/gomplate:stable
volumes:
- ${HA_PATH}/config:/config
command: -d 'data=file:///config/gomplate/mqtt_backup_entities.json' -f /config/gomplate/mqtt_backup_entities.tmpl -o /config/platforms/mqtt/gmp_backups.yaml
homeassistant:
container_name: home-assistant
depends_on:
condition: service_completed_successfully
- the result: a
file is generated:
## install:
## docker:
## run:
- name: "Backup daily cloud linx"
unique_id: "backup_cloud_linx"
state_topic: "backups/cloud/daily/linx"
value_template: '{{ value_json["datetime"] }}'
json_attributes_topic: backups/cloud/daily/linx
"type": "daily",
"src": "cloud",
"dst": "app",
"bucket": "cloud",
"prefix": "linx",
"status": "{{ value_json['status'] }}"
- name: "Backup daily cloud cloud2-data"
unique_id: "backup_cloud_cloud2_data"
state_topic: "backups/cloud/daily/cloud2-data"
json_attributes_topic: backups/cloud/daily/cloud2-data
"type": "daily",
"src": "cloud",
"dst": "app",
"bucket": "cloud",
"prefix": "cloud2-data",
- name: "Backup daily cloud cloud2-docker_files"
unique_id: "backup_cloud_cloud2_docker_files"
state_topic: "backups/cloud/daily/cloud2-docker_files"
json_attributes_topic: backups/cloud/daily/cloud2-docker_files
"type": "daily",
"src": "cloud",
"dst": "app",
"bucket": "cloud",
"prefix": "cloud2-docker_files",
- name: "Backup daily nas omv-backup"
unique_id: "backup_nas_omv_backup"
state_topic: "backups/nas/daily/omv-backup"
json_attributes_topic: backups/nas/daily/omv-backup
"type": "daily",
"src": "nas",
"dst": "nas",
"prefix": "omv-backup",
inclusion
The generated file (and others) is included through configuration.yaml
with:
mqtt:
sensor: !include_dir_merge_list platforms/mqtt/
